Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    May 2009
    Posts
    3
    Alma Ga.
    3000 ford
    Default 328 bobcat excavator
    need to pull machine because track motor blowing out hyd. fluid need to free track travel. Installed new fuel solenoid and machine still shuts down after cranking when you turn key loose. Machine will run if you tie solenoid back, possible blow seal in track motor so I need to pull to get it out of way.
  2. #2
    Elite Member Rustyiron's Avatar
    Join Date
    Mar 2011
    Posts
    4,203
    Lakes Region, Maine
    M 9540 Kubota
    Default Re: 328 bobcat excavator
    Switch (key) problem?
  3. #3
    New Member
    Join Date
    May 2009
    Posts
    3
    Alma Ga.
    3000 ford
    thanks i'll try that' if i can figure out how to get console out
Similar Threads
  1. Excavator cost per hour????
    By johnnyringo in forum Construction Equipment
    Last Post: 05-14-2011, 10:50 PM
  2. Bobcat for sale (the company)
    By jmfox in forum Toolcat
    Last Post: 07-18-2007, 09:48 PM
  3. HPX vs Bobcat 2200 vs RTV--Help!
    By jgh in forum ATVs & Utility Vehicles
    Last Post: 03-11-2007, 08:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
