farmhandjoe
- Joined
- Sep 1, 2011
- Messages
- 6
- Tractor
- BobCat 328
Hello everyone,
I have read through all of the BobCat postings and couldn't find a similar issue so I am hoping someone can shed some insight.
Basically, when the BobCat 328 starts it works fine. Has around 3100 hrs on it.
Usually I put the key in, turn it right and 3 lights come on (upper left (orange) and both right side ones (red)) along with a loud buzzing noise. Then it turns over and away I go.
Every once in awhile, when I go to start it, I turn the key right, I only get 2 red lights (bobcat-key-right.jpg), the upper left orange light does not come on, and then when I go to turn it over, it makes a rapid clicking noise, but the engine won't start.
To ensure the left upper light still works I turn the key left (bobcat-key-left.jpg) and it comes on.
I tested the battery connections and voltage and all is fine there, although when I hooked up a multimeter to the battery and tried to turn it over, the voltage dropped to 3.5v.
Oddly, the external headlights will not go on anymore while this non-starting issue is still happening.
Sometimes if I wait a few days and go to start it, it will work normally, as it should, and then the external lights work also.
This really perplexes me.
Could it be the glowplugs? Relay? Starter and/or solenoid?
Has any one had this happen before to them? Any ideas of what this means?
Thanks for any help you can provide.
Farmhand Joe
Farmhand Joe
