Re: 743 bobcat starter wont engage with good battery&starter just click then nothing-
I agree with thinking it is a ground. Get all the ground connections good and clean. If that doesn't do it, it sounds like it might be the solenoid. Check for voltage at the small stud on the solenoid when you turn the ignition key. Do this with the fuel-shut off in the up position so you don't accidentally start the loader. If you have good voltage there, move the volt meter to the side of the solenoid which has the cable running to the starter and check for voltage there while turning the ignition key. If no voltage is detected there, it is the solenoid.
