Results 1 to 4 of 4
  1. #1
    Join Date
    Mar 2006
    Posts
    173
    Greene, NY
    Jinma 254
    Default 753 Parts
    I found a Bobcat 853 that is being parted out. I was wondering if some of the parts from that machine (like the cab, exhaust, rear lights) would fit my Bobcat 753?
  2. #2
    Veteran Member SSdoxie's Avatar
    Join Date
    Jun 2010
    Posts
    1,548
    Cumberland Plateau, TN
    Bobcat CT225
    Default Re: 753 Parts
    If the ROPS (cab) look the same, then they are the same. Later 753 was also built in G-series cab while 853 was same as F-series. Other than ROPS that is about all these 2 models share. Different engines, exhaust, pumps, drive motors, chain case, axle, loader arm, cylinders - none of this would interchange with the 753.
    Dennis
    CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
  3. #3
    Join Date
    Mar 2006
    Posts
    173
    Greene, NY
    Jinma 254
    What is the difference from the F-series to the G-series?
  4. #4
    Join Date
    Jun 2010
    Posts
    1,548
    Bobcat CT225
    F- series has a lip on the roof that hangs over the front rectangular head lights, and the seat bar is hinged at the front of the cab. G-series has triangle shaped headlights and the seat bar is hinged at the back of the cab, behind the seat. One cab design will NOT interchange with the other.
    Dennis
Similar Threads
  1. Bobcat 753
    By crashz in forum Bobcat Construction Equipment
    Last Post: 10-22-2012, 06:49 PM
  2. 753 bobcat
    By bigearl42 in forum Bobcat Construction Equipment
    Last Post: 04-23-2012, 07:21 PM
  3. bobcat 753
    By hilltopdude in forum Bobcat Construction Equipment
    Last Post: 09-15-2011, 08:29 PM
  4. Bobcat 753
    By bluejedalu in forum Parts/Repairs
    Last Post: 10-30-2010, 05:45 PM
  5. Bobcat 753
    Last Post: 07-23-2010, 08:46 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
