trevelynzx
Hey guys, I've got a 2006 T300. Rented a trencher attachment and ran it for about 12 hours. Since then the T300 beeps at low idle and shows an error code: 05-14, extremely low hydraulic charge pressure. Bought the service manual but can't get much insight from it. A buddy looked at it and said the drive belt seems tight. We pulled the relay cap off of the pressure sending unit which let the machine run (instead of shutting it down when it's at a low idle).
Couple things:
1) Before pulling the relay the machine would beep at low idle and shut down in about 15 seconds. However, if I boosted the throttle the warning would clear and the machine seemed to operate normally.
2) After removing the relay the machine seems to have little to no hydraulic power to operate the lift & tilt at low idle. At high idle I feel like the machine doesn't have as much power as it should but it does operate. If I had to guess I'd say it seems like it lost 25% of its total power when at high idle.
3) I was running it yesterday at about 60% throttle. When moving forward/ backward there was a noticeable whining noise that seemed to be coming from both drive motors. Raising the throttle stopped the whining but it worried me because I'd never heard that before. (I did tighten the tracks that morning before beginning so I relaxed them a little bit. That didn't help the whining, but as mentioned above the throttle did.)
I feel like the low hydro pressure message is legitimate especially given that the machine seems underpowered. Should I get another pressure sensor? Any other diagnostic advice?
Couple things:
