Results 1 to 6 of 6
  1. #1
    Join Date
    Aug 2001
    Posts
    697
    South Texas
    Kubota M6800
    Default T190 damage while installing chain box?
    While installing a chain box I drilled two holes in the side and tapped them 3/8-16. I thought I would be drilling into nothing, but the drill hit something. What is behind this area?
    Attached Thumbnails Attached Thumbnails T190 damage while installing chain box?-image-3730394674-jpg
    JRP
  2. #2
    Elite Member Rustyiron's Avatar
    Join Date
    Mar 2011
    Posts
    3,365
    Lakes Region, Maine
    M 9540 Kubota
    Default Re: T190 damage while installing chain box?
    On skid steers, it is the chain case with the drive chains from the hyd. motor in the middle to each wheel hub. Usually there is a few inches of oil in the bottom for the chains to pick up lube. With your ctl with 1 drive motor in the back, I would have guessed that you would be fine dirlling/tapping also. If everything still works and no fluids are leaking or disapearing, run it. Check with your dealer to be sure, I've had Case, NH, JD & Gehl SS's but never a BC. Or ask at Skid Steers
  3. #3
    Veteran Member SSdoxie's Avatar
    Join Date
    Jun 2010
    Posts
    2,466
    Cumberland Plateau, TN
    Bobcat CT225
    The main control module (computer) is in that area, bolted to inside of the frame.
    Dennis
    CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
  4. #4
    Join Date
    Mar 2011
    Posts
    3,365
    Lakes Region, Maine
    M 9540 Kubota
    Quote Originally Posted by SSdoxie View Post
    Uh Oh!
  5. #5
    Join Date
    Aug 2001
    Posts
    697
    South Texas
    Kubota M6800
    Default
    Well, no problems yet.
    JRP
  6. #6
    Join Date
    Jun 2010
    Posts
    2,466
    Bobcat CT225
    If no problem by now you should be OK. That controller box is about 1 &1/4" thick with circuit board mounted to inward side, and back of it is filled with epoxy to seal it. My have just bumped up against the back side of it.
    Dennis
Similar Threads
  1. Tire chain damage to tractor?
    By Jeepnford in forum Tires
    Last Post: 03-22-2013, 09:47 PM
  2. Backhoe 909 on a T190
    By racerxsg in forum Attachments
    Last Post: 03-31-2012, 01:48 PM
  3. T190
    By Crosby in forum Bobcat Construction Equipment
    Last Post: 02-25-2012, 01:50 PM
  4. Tire chain damage
    By Gamemaster in forum Tires
    Last Post: 03-08-2007, 06:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
