Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Join Date
    Oct 2008
    Posts
    1,068
    Piedmont Triad, NC
    Didn't intend to have a Deere fleet - it just happened 310C, F915,102 & 5200
    Default Re: Overturned bobcat excavator
    The excavator has been extricated! Didn't take $2000 of crane time. A reputable crane company suggested a better solution. A heavy OTR hauler and experience pulled it out in a few minutes. Notice the two cables. By jockeying the excavator between the cables no further damage was sustained.
    Overturned bobcat excavator-up-jpg Overturned bobcat excavator-out-jpg
  2. #12
    Join Date
    Mar 2009
    Posts
    130
    Arkansas
    Belarus 825, for now.
    Default
    Bet that wasn't cheap either....but cheaper than a crane.
  3. #13
    Veteran Member yelbike's Avatar
    Join Date
    Nov 2011
    Posts
    1,643
    Near Winnipeg, Mb, Canada
    John Deere 2305, 2320,Z465
    I wear my seatbelt even tilling on flat land. I may look like a dork to some but at least I should be ok in a roll over. Glad no one was hurts. How's the engine?
    Carefull what you aim for, Aim for nothing and you will achieve it with amazing accuracy.
  4. #14
    Join Date
    Oct 2008
    Posts
    1,068
    Piedmont Triad, NC
    Quote Originally Posted by yelbike View Post
    Owner is letting the machine sit a while. Hoping most of the engine oil will drain down. Before starting, he'll do a fluid service and turn the engine over by hand.
  5. #15
    Gold Member HarryN's Avatar
    Join Date
    Aug 2011
    Posts
    289
    Covington, Louisiana USA
    1999 Bobcat 763F John Deer 850 Grasshopper 723K H2
    When something like this happens, (side ways, upside down, etc) how long does it take before the engine shuts down?
    Are operators quick enough to shut it down by hand, while they worry about where they are about to go?
    Would it save anything if it gets shut down soon enough??
  6. #16
    Elite Member SSdoxie's Avatar
    Join Date
    Jun 2010
    Posts
    2,514
    Cumberland Plateau, TN
    Bobcat CT225
    No oil pressure shut down will occur in about 30 seconds, sufficient time to save engine from lubrication damage. The greater risk in this case is oil flowing into the valve cover, through the PVC valve to the intake manifold and getting drawn into cylinders and bending rod while it is still running.
    Dennis
    CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
Similar Threads
  1. Backhoe BOBCAT 337 Excavator need help
    By ccellc in forum Attachments
    Last Post: 03-01-2013, 01:34 AM
  2. Buying Advice bobcat 341 excavator
    By ultraglide62 in forum Bobcat Construction Equipment
    Last Post: 04-07-2012, 11:23 PM
  3. 328 bobcat excavator
    By johnwjohn in forum Bobcat Construction Equipment
    Last Post: 04-06-2011, 08:56 AM
  4. bobcat 116 excavator
    By deadend in forum Bobcat Construction Equipment
    Last Post: 09-27-2010, 03:28 PM
  5. Tractor News Bobcat 322 excavator
    By wkiwan in forum Bobcat Construction Equipment
    Last Post: 07-23-2010, 08:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
