Results 1 to 2 of 2
  1. #1
    Member
    Join Date
    Dec 2011
    Posts
    42
    Default 643 bobcat battery recomendation
    Have a 85 643 kubota 3 cyl deisel and I'm curious as to what cca battery would you recommend? Seems to crank pretty hard on a very cold day an after runnin the glow plugs there's not much battery left to crank with... This one is one month old but only 700 cca @32
  2. #2
    Elite Member SSdoxie's Avatar
    Join Date
    Jun 2010
    Posts
    2,528
    Cumberland Plateau, TN
    Bobcat CT225
    Default Re: 643 bobcat battery recomendation
    Those engines required a lot of glow plug, pre-heat even when new. More battery you have the better (more reserve capacity). Keeping the battery warm using a battery blanket or trickle charger will increase the reserve capacity.
    Dennis
    CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
Similar Threads
  1. Bobcat 643 cylinder leak
    By Shortbed70 in forum Bobcat Construction Equipment
    Last Post: 06-04-2012, 04:04 PM
  2. Bobcat 643 w/kabota d1402
    By The shootist in forum Parts/Repairs
    Last Post: 03-10-2012, 03:15 PM
  3. Bobcat 643
    Last Post: 01-16-2012, 08:44 PM
  4. Questions on a 643 Bobcat
    By lazermule in forum Bobcat Construction Equipment
    Last Post: 05-08-2010, 04:16 PM
  5. Bobcat skidsteer 643
    By pistols4r in forum Bobcat Construction Equipment
    Last Post: 02-08-2010, 02:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
