buster1
I have 2300 lbs a full throttle at hydraulic pump what should it be?
Once again.
Hydraulic System
334
Auxiliary Std Flow 16.4 GPM
Auxiliary Pressure 2600 psi
Bobcat Historical Specifications - Bobcat Company
Adjust it to secs and you should get a little more.
As far as speed of operation, if you are putting the rated GPM, that is the best you can do.
You will gain some force by adjusting the relief to 2600 psi.
You could cheat and go higher, but that is up to you.
