Dirtdigger5
I asked the Service Department of the local Bobcat dealer this question a few days ago and still no response so I will try it on here. Does a V417 have a wiring harness for a radio somewhere under the dash? The operator's manual shows a couple of fused circuits for a radio but I would rather not start pulling things apart to search if there is no harness, You have to have the arms of a double-jointed orangutan and the hands of a midget to get at the electrical circuits on these machines.
And while I am on the topic of radios has anyone purchased the Tractor Tunes stereo system that is advertised in the TBN store? Is it battery operated or do you wire it to the machine's electrical system? Does it have an internal or external antenna? Right now, I am using a small portable radio plugged into a 100 watt inverter which is plugged into the cigarette lighter socket but the reception is poor.
If you are going to use something other than a cigarette lighter in that socket in a V417 check it out first. Bobcat had the hot wire going to the side of the socket that you would expect to be grounded. No biggy for a lighter coil but a voltage inverter sure didn't like it. I wonder if they do the same thing in their skid steers?
