masalser
- Joined
- Feb 10, 2008
- Messages
- 55
- Location
- Snohomish County, Washington
- Tractor
- John Deere 5510, Kubota HST 3010, ASV RC100 tracked skidsteer, Bobcat 435 excavator, Howard Price 15' finish mower, Kubota ZD331 mower, Woodmizer LT40 super hydraulic sawmill
I've got a 435 Fasttrack that is currently having a drive belt issue. I've clearly neglected it and as a result the drive belt tension indicator shows that it is way loose. It currently has about 600 hours on it and back at around 300 hours that drive belt tensioner was replaced by the dealer as faulty. It looks like I may have the same problem of a broken tensioner again.
I put the jack bolt in from the bottom in order to adjust the tension, but the tensioner is already so high up that the belt is in the way of the bolt that holds it in position, and I can't really see how to loosen it. It seems like when the dealer messed with it last time they moved it way up well beyond what is shown in the manual pictures and had enough apart that they were able to tighten it in that position. The thing that sucks is the dealer I used to take the machine to is gone now and the closest dealer is now about a 2.5 hour drive away.
I have a heavy equipment mechanic that I can hire to work on it, but he won't have much experience with this particular machine. My questions are:
1) has anyone else had this problem and is it possible that there is an updated tensioner pulley?
2) does anyone have a good recommendation for an online place to order parts?
3) I'm assuming that I should order a new belt and replacement tensioner - does that sound reasonable to any of you who have experience with this machine?
Thanks for any help you can provide. I've attached a photo showing the tensioner and the bolt holding it in place. You can see by the clean area above the washer that it looks like I moved tensioner up a little bit when I put the jack screw in, so I'm guessing that the bolt that is supposed to be holding the tensioner in place is looser than it should be.
