Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
  1. #21
    Gold Member gumshu's Avatar
    Join Date
    Jun 2009
    Posts
    467
    Atascadero, Ca. & Selma, Or.
    Kubota M7040, Bobcat CT235, Kubota BX23 TLB & RTV 900
    Default Re: bobcats spendy hyd fluid
    Quote Originally Posted by RETAF View Post
    Hey gumshu, I also have an 09 Bobcat 235 and have similar problems...my oil cooler leaks(have to spray wash it after 5-10 hours) Did you say Bobcat has changed them and is it a warranty issue. If not I suppose I should just buy one and install it as I'm nearing my 400 hours service. I have also had nothing but problems with the loader hydraulic hoses leaking, had to replace all four...now the female receiver hydraulic couplers(under the tractor) are leaking...very poor design to have them in one of the dirtiest places on a tractor. I also had the battery acid issue...guess I'll get a sealed one, sounds like that fixed your problem . Shifting is a bit sticky, but workable. Now I need to replace the hydro fluid and you're saying there is other fluid that will work for less money? Guess I'll wait for the 400 hour change as I'm only down between 'full' and 'add'. Great forum...nice to know the problems I'm having aren't just with my tractor. Great unit even with the little problems. Only thing else I find had to find and the belly mower blades for the 66" cutting deck!
    Hi Retaf. According to some of the posts on this forum, some owners have the newly designed oil cooler. I imagine that if leaks occur within the warrantee time frame, there should not be an issue. However, I'm surprised that Bobcat hasn't issued a recall on this.
    I'm using the Super tech Heavy duty universal fluid sold at Wal Mart... I paid about 90 bucks for two five gallon containers with easy pour spouts. I poured the fluid into a 1 gallon juice container and then into the tractor using a funnel.
    I also had a battery acid leak. I replaced the battery with a sealed Sears Die Hard. If your hoses are leaking you may want to try using reusable hose fittings from this site DiscountHydraulicHose.com
    F350 6.4 Dually, PJ 14K 20', PJ 3.5K
  2. #22
    Bronze Member pwright's Avatar
    Join Date
    Aug 2012
    Posts
    95
    Las Cruces, NM
    2012 Bobcat CT225
    Quote Originally Posted by jaford1 View Post
    Where do you get the Traveler TS brand you mentioned and is that the name on the container?
    I believe he is referring to the fluid available from Tractor Supply Co.
    Traveller® Universal Tractor Trans/Hydraulic Fluid, 5 gal. - 0806391 | Tractor Supply Company
    It's $40/5gl.
    Phil
    Bobcat CT225 with FEL and Bobtach.
    Landpride box blade, post hole digger and pallet forks.
  3. #23
    Join Date
    May 2012
    Posts
    2,264
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by pwright View Post
    I believe he is referring to the fluid available from Tractor Supply Co. It's $40/5gl.
    So the real question is, if I go with the cheaper TSC or Wal-Mart stuff, am I going to regret it later? Is the OEM stuff really that much better, or is it just marked up because it's from a dealer? If it is better, is it better "enough" to matter, or is it going to be the (arguably negligible?) difference between 10000 hours and 10500 hours on the engine?
  4. #24
    New Member
    Join Date
    Jul 2012
    Posts
    7
    Spring Creek, Nevada
    Bobcat CT235
    It's $40/5gl.
    Hi pwright,
    Thanks for the information and the link,
    Jim
  5. #25
    Join Date
    Jun 2009
    Posts
    467
    Hi pwright,
    Jim
    I was going to use the Travelers Brand, but Tractor Supply was closed at the time, so I bought the Wal Mart brand for a little more. I haven't heard any negative reviews about either.
  6. #26
    Join Date
    Aug 2012
    Posts
    95
    Las Cruces, NM
    2012 Bobcat CT225
    Quote Originally Posted by joshuabardwell View Post
    So here is the back label where it indicates what it is recommended for with the equivalent manufacturer part numbers. Sorry about the wonky focus.
    Phil
  7. #27
    Platinum Member MESSMAKER's Avatar
    Join Date
    May 2009
    Posts
    690
    Bluegrass,KY
    Bobcat ct 225
    I don't remember the specs on the Phillips 66, but I bought it from a oil guy I trust who said he sells it to all the rental places in town. He said it was great stuff. I was not super cheap as I remember. I think it was about $65 for 5 gal. That being said, I think it is all OK. Some hydraulic systems work just fine on motor oil. That is how they were designed. I just don't think it is rocket science.
  8. #28
    Join Date
    Jun 2009
    Posts
    467
    Click image for larger version.
    Yeah... the specs on the Wal-Mart Super tech look the same. I'm not buying the Bobcat brand for twice the money.
  9. #29
    New Member
    Join Date
    Jul 2012
    Posts
    7
    Bobcat CT235
    Hi messmaker,
    Thanks for the information. I agree it is not rocket science, I remember on a D2 cat we used for cultivating our orchards when I was you all we used was motor oil and it worked just fine.
  10. #30
    Join Date
    Nov 2009
    Posts
    1,701
    USA
    Bobcat
    I have very little difficulty shifting ranges, its not as smooth as a automobile gear tranny, but rocking the treadle does the trick for me
Similar Threads
  1. changed hyd fluid now brakes are squealing
    By Michael Knight in forum Kubota Owning/Operating
    Last Post: 07-02-2008, 02:39 PM
  2. OK to mix AW-32 and "general" tractor hyd fluid?
    By joerocker in forum Oil, Fuel & Lubricants
    Last Post: 06-23-2008, 12:57 PM
  3. how does the hyd fluid
    By accordionman in forum Massey Ferguson Owning/Operating
    Last Post: 01-23-2007, 03:44 PM
  4. Strange BX 24 Hyd Fluid Leak
    By DickS in forum Kubota Owning/Operating
    Last Post: 01-16-2007, 01:43 PM
  5. change the brake fluid?
    By Doc_Bob in forum Owning/Operating
    Last Post: 11-23-2006, 10:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
