Results 31 to 40 of 44
08-20-2012, 03:47 PM #31New Member
- Join Date
- Aug 2012
- Posts
- 2
- Location
- Detroit Lakes, MN
- Tractor
- Bobcat 235
Re: bobcats spendy hyd fluid
Thanks Gumshu...I'll check out those hydraulic fittings. I'm also going to see about a replacement battery....unfortunately the oil cooler is out of warranty...oh well, just replace it and move on. I do think I'll talk with Bobcat and see if they will do something....sounds like a common problem on these tractors..09 and older!!
08-24-2012, 01:23 PM #32
Here is my .02 worth... I changed all my fluids, I paid the higher cost for the Bobcat brand. Reason being, if I need warranty work, I dont want them to question the fluids I used. After the warranty period is up, well thats when I would consider a different brand. I am sure there is not any difference in the oils, but its the fine print on the warranty card that would be the issue.
...I have all the answers, can you wait a minute while I ask my wife?
2010 Bobcat CT335, 5' King Kutter Hog, 5' Bush Hog Finish Mower, 14" 2 Bottom Plow, 6' V Discs, 8' Chain Link Harrow, 7' Bush Hog Back Blade
08-24-2012, 05:44 PM #33
+1, I too used the fluid and filters from Bobcat, have no idea if their fluid is better than others. I do know that for every repair somebody gets charged for it, so if I do have a failure the tractor, fluid in it, and filters carry the same name so Bobcat would approve the repair and I get my tractor back working and then they can try to decide if it was component, fluid, or filter that caused it. If the fluid or filter carries another name, then the manufacturer (Bobcat, Kubota, John deere, whatever) will take time to find the cause of failure or rule out fluid and filters before approving repair.
Fedral law prohibits any company from denying warranty if maintenance items are not purchased from them, but on same note they are not obligated to pay for a repair caused by something that they did not make or sell.Dennis
CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
08-24-2012, 10:48 PM #34Gold Member
- Join Date
- Jun 2009
- Posts
- 467
- Location
- Atascadero, Ca. & Selma, Or.
- Tractor
- Kubota M7040, Bobcat CT235, Kubota BX23 TLB & RTV 900
If your tractor is under warranty then most definitely go with their fluid. That's the wise thing to do. I'd do the same. For me... my warranty is up. I still buy their filters, but I'll use another brand for fluid. Mobil fluid 424 and Shell Donax are other popular alternatives, but pricy. If there was a problem associated with a particular brand of fluid, that company would be liable for damages. I doubt if major stores like TSC and Wally Mart would not stand behind their product. So far so good and coming up on another change soon.
F350 6.4 Dually, PJ 14K 20', PJ 3.5K
08-24-2012, 11:06 PM #35
08-25-2012, 12:10 AM #36Platinum Member
- Join Date
- May 2011
- Posts
- 697
- Location
- Trent Hills, ON
- Tractor
- Kioti DK40SE HST
My take on hyd. oil is that Kubota or JD or any of the tractor brands specs listed on the buckets don't actually test the oil, you are simply trusting that the hyd. oil manufacturer makes sure their product meets those specs. If Shell or Chevron or Mobil could meet the specs and sell the oil for the prices that that the "no-name" ones go for, wouldn't they under-cut their major competitors, to gain market share?
It would be nice to see some official testing by the API like they do for motor oils, but in the absence of that, I'm going to stick with name brands.2011 DK40SE HST
09-10-2012, 11:50 AM #37Gold Member
- Join Date
- Dec 2006
- Posts
- 367
- Location
- Sullivan, WI
- Tractor
- 2011 Bobcat CT235
09-10-2012, 04:15 PM #38
09-10-2012, 06:22 PM #39Gold Member
- Join Date
- Jun 2009
- Posts
- 467
- Location
- Tractor
DFKRUG... The Wal-Mart brand does provide specs and claims to be a UDT equivalent. That's what I used for my last replacement and still have the bkts in my garage. I checked the specs before buying. I believe TSC's specs to be the same as I've seen other posts of people claiming to use it for their Kubotas. I was actually looking for Shell Donax or Mobilfluid 424, but those are hard to find around here.
09-10-2012, 06:35 PM #40Elite Member
- Join Date
- Feb 2004
- Posts
- 4,100
- Location
- NorCal
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe
Yes, I have heard they are carrying deluxe THF now, but I have not seen it. I would have
no problem using that, or the good stuff at TractorSupply. Both places have sold fluids in the
past that do not list branded equivalences on the label.
To add to the Acceptable list, I have recently bought 5-gal bkts of ServicePro THF, which is
listed as J20 and UDT equivalents. I got mine at a oil wholesaler, but I see that the local
NAPA carries it, too. Looks/smells exactly like the other THFs I have bought.See my TBN projects at:
http://mysite.verizon.net/resyfcgt/
Similar Threads
changed hyd fluid now brakes are squealing
By Michael Knight in forum Kubota Owning/OperatingReplies: 6Last Post: 07-02-2008, 02:39 PM -
OK to mix AW-32 and "general" tractor hyd fluid?
By joerocker in forum Oil, Fuel & LubricantsReplies: 2Last Post: 06-23-2008, 12:57 PM -
how does the hyd fluid
By accordionman in forum Massey Ferguson Owning/OperatingReplies: 11Last Post: 01-23-2007, 03:44 PM -
Strange BX 24 Hyd Fluid Leak
By DickS in forum Kubota Owning/OperatingReplies: 7Last Post: 01-16-2007, 01:43 PM -
change the brake fluid?
By Doc_Bob in forum Owning/OperatingReplies: 11Last Post: 11-23-2006, 10:13 PM
