Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Join Date
    Jun 2009
    Posts
    59
    Default Re: Front snow plows
    As one with a loader mounted plow (plumbed from the rear remotes), I can say it works just fine on my CT225. I live in WI and plow a small driveway and often the road to my house (township road). Like anything, it is not indestructible. You should always try to plow with the blade as straight as possible and in the float position. This setup is great because you can plow into a pile and then lift it up and over. Can't do that with a truck plow.
    CT225 w/ 7TL Bob-Tach loader
    Deluxe suspension seat, rear hydraulics, mid PTO
    Woods RD7200 6' rear discharge finish mower
    Buhler C84SS 7' rear blade
    Meyer 6'6" loader mounted custom Bob-Tach snow plow
  2. #12
    Silver Member MF1652's Avatar
    Join Date
    Feb 2010
    Posts
    209
    Vermont
    2016 John Deere 3039R
    plowing is destructive on any equipment you use. I use a loader mounted plow which operates off the rear remotes. Like anything, you just have to be careful what you do. Stuff will break if you abuse it. For me it was a question of whether I should use my tractor to plow or my truck. I decided it wasn't worth beating on my truck, so I went with the tractor for plowing. I need my front loader bucket on an almost daily basis for manure removal, so attaching a plow to a frame under the tractor wasn't a good option. For me the best option was the skid steer mount on the loader. From my experience with both loader mounted plows and truck plows, I can move more snow, pile it higher, have better maneuverability and have yet to get struck like when I used a pickup to plow. No setup is perfect if misused. I've broken truck plows as well.
  3. #13
    Join Date
    Mar 2008
    Posts
    1,499
    Maine
    Deere 3520 Cab, Deere F935
    Quote Originally Posted by Duffster View Post
    It works great but puts a huge side load on the loader arms which can be easily torqued.
    Some people get by just fine and some do not.
    Totally agree...While I love my loader mounted blade, I wouldnt put an "angle plow" on a loader of any sort. Heres one I built for my Bro's BCat...I've got the same setup on mine....Doesnt place any different stress on the loader then a Bucket would. He uses his to plow, but he gets less snow then I do. I just use mine for cleanup...back drag snow away from the buildings and then I can get to everything with my 3pt Blower.
    Attached Thumbnails Attached Thumbnails Front snow plows-dsc01949-jpg
  4. #14
    Super Member
    Join Date
    Nov 2009
    Posts
    5,764
    Indiana
    Bobcat
    Quote Originally Posted by Spudland_Dave View Post
    how wide is that blade?
  5. #15
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,577
    Lincoln County, NC need new avatar!
    Just a Scag
    Quote Originally Posted by MF1652 View Post
    Given your circumstances, I'd probably do the same. I am not a fan of truck mounted plows unless there are several jobs a long distance apart. I very much prefer a frame mounted plow on a tractor, but I also have a different tractor with FEL.
    Spring is the season of optimism.
  6. #16
    Join Date
    Mar 2008
    Posts
    1,499
    Maine
    Quote Originally Posted by lilranch2001 View Post
    The one I built for his Bobcat is a 60", I buit it totally from scratch.
    Mine is a 90" Fisher I modified...
    Attached Thumbnails Attached Thumbnails Front snow plows-dsc01946-jpg   Front snow plows-blade3-jpg   Front snow plows-snowrig1-jpg
  7. #17
    Elite Member Rob-D's Avatar
    Join Date
    Oct 2006
    Posts
    3,078
    Catskills
    John Deere 3320
    Nice job dave! I'll bet that rig moves a lot of snow.
    Rob
Similar Threads
  1. Rear snow blower or front mounted snow blower
    By Doc_Bob in forum New Holland Buying/Pricing
    Last Post: 10-29-2012, 12:04 PM
  2. Snow Attachments Snow: Rear Blade vs Hydraulic Front Blade
    By bp fick in forum Snow Removal
    Last Post: 01-15-2011, 02:06 PM
  3. Snow MF front mount snow blower / FEL change?
    By Don 57 in forum Massey Ferguson Owning/Operating
    Last Post: 02-27-2010, 04:47 PM
  4. Snow Snow chans, front tires, TC33d with R4s...
    By KrisHansen in forum New Holland Owning/Operating
    Last Post: 01-06-2008, 03:10 PM
  5. Optional "A-Frame Front Hitch" on 3x20/4x20?
    By bam747 in forum John Deere Buying/Pricing
    Last Post: 04-13-2006, 04:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
