Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Gold Member
    Join Date
    Sep 2008
    Posts
    343
    Poniatowski, WI
    Bobcat CT225
    Unhappy My snow shovel is leaking oil
    Six inches of fresh snow. "Several" inches forecast for Monday.
    Uh-oh...
    Attached Thumbnails Attached Thumbnails My snow shovel is leaking oil-dsc_2245-jpg
    Bobcat CT225
    middle buster, three-point forks, chain-on brush forks
    "borrowed" drag & disc stored at my house
  2. #2
    Gold Member
    Join Date
    Sep 2008
    Posts
    343
    Poniatowski, WI
    Bobcat CT225
    Default Re: My snow shovel is leaking oil
    Oil running over the muffler and front axle.
    Source is a small leak near the top of the oil cooler.
    My dealer is closed for the weekend. Next closest dealer doesn't have the part in stock.
    -rus-
    Attached Thumbnails Attached Thumbnails My snow shovel is leaking oil-dsc_2247-jpg   My snow shovel is leaking oil-dsc_2248-jpg
    Bobcat CT225
  3. #3
    Join Date
    Mar 2005
    Posts
    1,844
    Erie, Pennsylvania
    Kioti CK30HST
    It looks very similar from your picture but I can't tell for sure if they redesigned the oil cooler or mounting. The Kioti CK25 and 30, twins of the CT225 and 230, had these issues. I replaced one under warranty and then another after warranty on my CK30hst. About 125 and 100 hours respectively. If the cooler is still mounted with two studs and nuts going through the top of the cooler to a horizontal support in front of the radiator, then the trick is to mount it with rubber grommets. I had drilled the holes in the cooler a little larger, placed a rubber grommet in each hole, cut two 5/16" long by 1/4" diameter steel tubing sections to go into the grommets and then passed the steel tubing over the studs with the nuts tightening down on the steel tubing. It relieves much of the vibration and I'm still good with 150 hours on the cooler. Other Kioti owners of these models had to do the same with good results.
  4. #4
    Silver Member NOTV8's Avatar
    Join Date
    Apr 2010
    Posts
    240
    CT235
    That sux with more snow coming... Hope you get it fix "McGyver style" 'till you get the right part with that snow coming .
    2010 CT235 with Bobtach, Rear Remotes, FEL, Kioti 60" Boxblade, 36" Fork, Snow-Sport Snow Plow, Wally BX42 Chipper, Land Pride LR 1584, Land Pride RB 1584, Gator 48" Grapple, HTL, Woods BH7500, HF 3PT Hitch Quick Attach, HF 3PT Hitch (Modified to work with BobTach in Front)
    CT 235 traded for CT 440 with free 72" snow blower...
  5. #5
    Join Date
    Jun 2009
    Posts
    625
    Nowhere
    1878 Ford 65N
    Your fix is to connect the oil cooler lines and by-pass the cooler. In freezing temperatures you'll never need a cooler.
    Check my post about the cracked cooler. I experienced this and its an easy fix.
  6. #6
    Super Member
    Join Date
    Aug 2004
    Posts
    6,338
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    Quote Originally Posted by Canada_CT230 View Post
    That,
    or is the cooler brass or copper?
    If so, solder and plumber's torch can make a quick fix!
    If plastic (top/bottom) or aluminum stiff rubber and clamping can control or stop the leak on a temporary basis.
    Pressure is not an issue in that it will be fairly low (assuming the cooler is on return side).
  7. #7
    Join Date
    Jun 2009
    Posts
    625
    Nowhere
    1878 Ford 65N
    You solder it....no warranty replacement. Out of warranty...go for that solution.
  8. #8
    Join Date
    Mar 2005
    Posts
    1,844
    Erie, Pennsylvania
    Kioti CK30HST
    Quote Originally Posted by PILOON View Post
    That,
    The cooler should be all aluminum and I could never exactly tell where mine was leaking. Mine leaked very little and was just wet all the time. Your cooler seems to have a good leak and maybe you can find it.
    And as mentioned, if you solder it, warranty probably won't cover a tampered part.
  9. #9
    Gold Member
    Join Date
    Sep 2008
    Posts
    343
    Poniatowski, WI
    Bobcat CT225
    Once the part comes in, the dealer is going to install it at my house. Makes more sense than trailering the tractor both ways. Unfortunately have to wait until Thursday...
    Bobcat CT225
  10. #10
    Gold Member ihuntbear's Avatar
    Join Date
    Jan 2010
    Posts
    430
    new brunswick, canada
    2015 tym T554 and 1999 Kobota m4700
    if its aluminum you can plug it with epoxy.I used to use it for refrigeration condensers. good temp fix until part comes in
Similar Threads
  1. Global Warming News
    By KB9UDE in forum Rural Living
    Last Post: 03-11-2010, 09:06 AM
  2. Snow Equipment Owning/Operating Snow blowing rules of thumb
    By smfcpacfp in forum Snow Removal
    Last Post: 02-13-2010, 04:41 AM
  3. GM Oil Life Monitor
    By Doc_Bob in forum Oil, Fuel & Lubricants
    Last Post: 10-10-2009, 08:15 PM
  4. JD Gator-Gas in oil
    By Grapeman in forum ATVs & Utility Vehicles
    Last Post: 03-20-2008, 10:39 PM
  5. Is Amsoil API certified?
    By saparks10 in forum Oil, Fuel & Lubricants
    Last Post: 10-02-2007, 07:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
