Results 1 to 5 of 5
  1. #1
    Join Date
    Jan 2009
    Posts
    99
    End of the road, NE South Dakota
    Bobcat CT235
    Default additional work lights on ct235
    So I finally got around to taking some pictures of the additional work lighting that I installed on my CT235. For the front work lights I wanted to get them up a little bit above the loader arms to get the beams out over the top of the bucket. The rear is tucked in next to the rops where it is out of the way. The rear light is hooked onto the factory wire for rear work light. The front lights are hooked into an extra fuse slot in the fuse panel then wires through a relay. The front lights have plugs on the wiring to disconnect them when the loader is removed (although the laoder has never been off of this tractor) Here is:
    Attached Thumbnails Attached Thumbnails additional work lights on ct235-dsc_0011-jpg   additional work lights on ct235-dsc_0012-jpg
    2009 Bobcat CT235 with front end loader
    Bobcat snowblower
    King Kutter 60" tiller
    More attachments to come in the future....1st up.....60" box blade
    2015 Kubota M100GX with heated glass and loader/grapple
  2. #2
    Gold Member
    Join Date
    Dec 2006
    Posts
    395
    Sullivan, WI
    2011 Bobcat CT235
    Default Re: additional work lights on ct235
    I heard from the dealer when I picked up my rear light that they now make a set that mounts to the ROPS???
  3. #3
    Gold Member
    Join Date
    Apr 2009
    Posts
    401
    Rushville, IN
    Bobcat CT230
    Nice job. I can't tell from the pic but do you just have one front and one rear? Where did you get your lights? I have been thinking about putting some extra lights on mine but just have too many other projects in the works.
  4. #4
    Join Date
    Jan 2009
    Posts
    99
    Bobcat CT235
    I have 2 front and 1 rear. I got the lights at Tractor Supply and the brackets are made from 1/4" X 2" flat steel.
    Bobcat snowblower
  5. #5
    Bronze Member Sand_man's Avatar
    Join Date
    Apr 2009
    Posts
    51
    Michigan
    Bobcat CT335
    Your lights look good. I did something similer to mine. Bought 3 rubber mounted lights from Napa, 11 $ a piece, and mounted them with angle iron off off the ROPS. Yes I drilled and tapped the ROPS, please don't tell anybody. http://www.tractorbynet.com/forums/c...84-lights.html
    Bobcat CT335 with loader, 2 bottom plow, 3pt disc, 5' tiller, 72" Everything Attachments HD Box Blade
Similar Threads
  1. Adding work lights
    By Greatwideopen in forum Kubota Owning/Operating
    Last Post: 03-22-2011, 11:15 PM
  2. work lights
    By nealfris in forum Customization
    Last Post: 03-01-2011, 05:52 PM
  3. Additional work lights on 4720 with cab
    By TCowner in forum John Deere Owning/Operating
    Last Post: 11-21-2009, 01:28 PM
  4. BX2350 Lights on Rops - FEL work at night
    By Musclford in forum Kubota Owning/Operating
    Last Post: 12-08-2006, 12:05 AM
  5. How do I add lights to my GC2310?
    By Cucch in forum Massey Ferguson Owning/Operating
    Last Post: 12-05-2006, 02:13 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
