Results 21 to 30 of 34
06-11-2011, 12:43 AM #21Platinum Member
- Join Date
- Jun 2004
- Posts
- 657
- Location
- Armstrong, BC
- Tractor
- Kioti DK35 SE HST (2011)
Re: Toolbox
The chainsaw case is 3 pieces of 1/2" plywood, all cut the same with the bottom edge more or less following the contour of the loader mounting bracket. I traced an area a bit larger than the chainsaw bar on one of the pieces and sandwiched it between the other two using white glue and some small (#8?) bolts. The bolts likely weren't necessary.
The holder mounts using the two existing holes in the loader mounting bracket.
Before gluing I installed a carriage bolt for the top connection to the loader bracket and drilled a hole opposite it in case I needed to access the bolt. That likely wasn't necessary and I should have just glued the bolt in the wood.
The bottom connection is an ordinary bolt that goes through all three pieces of plywood (i.e. the chainsaw bar is completely above the bottom bolt).
I have attached a cropped picture that may help.
I see the chainsaw's bumper spike is resting on the case. But I actually grooved the back piece of plywood and the bumper spike fits over the rear side of the case with the main body of the saw resting on the holder.
I got the idea for this from tornadowatchranch and the ideas for using plywood from other posters on TBN.
06-11-2011, 07:45 AM #22Silver Member
- Join Date
- Apr 2011
- Posts
- 116
- Location
- rolla missouri
- Tractor
- bobcat 440
Re: Toolbox
some very nice ideas on what to do with the chains and saw, i had been struggling with what to do with mine. thanks for the ideas and photos
06-12-2011, 07:02 PM #23
06-14-2011, 08:00 AM #24Member
- Join Date
- May 2010
- Posts
- 27
- Location
- PA
- Tractor
- Bobcat CT335
Re: Toolbox
03-10-2012, 12:08 PM #25
Re: Toolbox
I thought I would add my toolbox to the mix. It's a "boater's waterproof box" from the boating section of my Walmart. I mounted it to the spot where the owners manual used to sit.
So far it has been great and everything stays completely dry!
03-10-2012, 06:30 PM #26Veteran Member
- Join Date
- Nov 2009
- Posts
- 1,701
- Location
- USA
- Tractor
- Bobcat
Re: Toolbox
did they move the fuel tank from under the hood on newer models of Bobcats?
03-10-2012, 06:43 PM #27New Member
- Join Date
- Apr 2011
- Posts
- 19
Re: Toolbox
Using storage designed for boating actually seems like a pretty good idea, especially since the one in your picture is narrow and more likely to fit behind the seat as opposed to something like the waterproof Stanley tool box that I ended up with, which just barely fits between the tractor seat and backhoe seat.
03-10-2012, 06:46 PM #28
03-10-2012, 06:52 PM #29Platinum Member
- Join Date
- Jun 2009
- Posts
- 625
- Location
- Nowhere
- Tractor
- 1878 Ford 65N
03-10-2012, 07:37 PM #30Veteran Member
- Join Date
- Nov 2009
- Posts
- 1,701
- Location
- USA
- Tractor
- Bobcat
Similar Threads
Where to put toolbox on little Kubota?
By jeffreythree in forum CustomizationReplies: 26Last Post: 05-15-2011, 08:36 AM -
T2320 Toolbox Kit...a little disappointing
By peterssj4034 in forum New Holland Owning/OperatingReplies: 10Last Post: 01-08-2011, 03:21 PM -
Extra Toolbox location
By unaka in forum Massey Ferguson Owning/OperatingReplies: 4Last Post: 03-12-2002, 11:38 AM -
Toolbox for New Holland TC40 or TC45
By tpaulson in forum CustomizationReplies: 1Last Post: 10-12-2001, 11:36 AM -
Toolbox Dilemma Resolved
By FarmerBob in forum PhotosReplies: 13Last Post: 06-05-2001, 11:47 AM
