Page 2 of 6 FirstFirst 12345 ... LastLast
Results 11 to 20 of 60
  1. #11
    Silver Member SABULA FARMER's Avatar
    Join Date
    Feb 2007
    Posts
    225
    Pennsylvania
    Bobcat CT335SST
    Default Re: Tach/Electrical Issue
    Ok same issue here with my CT335....I have no Tach, or idiot lights. If I turn the ignition switch several times they will come on....WTH?
    I am calling the dealer tomorrow.
    S.F.
    ...I have all the answers, can you wait a minute while I ask my wife?
    2010 Bobcat CT335, 5' King Kutter Hog, 5' Bush Hog Finish Mower, 14" 2 Bottom Plow, 6' V Discs, 8' Chain Link Harrow, 7' Bush Hog Back Blade
  2. #12
    Join Date
    Aug 2010
    Posts
    53
    Whitesburg, KY
    2010 Bobcat CT335ss
    Quote Originally Posted by SABULA FARMER View Post
    S.F.
    Let us know what you find out!
  3. #13
    Join Date
    Aug 2010
    Posts
    53
    Whitesburg, KY
    2010 Bobcat CT335ss
    Spent most of the day checking the ground and positive cables, no issues found.
    The ONLY power I get to the dash is turning the key backwards and I get the glow plug light, with key off I can turn flashers on and hear the flasher buzzing-clicking but the lights do not lite up.
    Occasionally I can move the key to the on position and hear the relays licking, but that rarely happens.
    I do get good voltage to the key switch.
  4. #14
    Veteran Member milkman636's Avatar
    Join Date
    Aug 2010
    Posts
    1,176
    Palm of the Right Hand
    Bobcat CT335 + Kubota BX2370-1
    I had trouble with my tach and gauges not working a couple times last fall. I ended up having to pull the ground cable from the battery off the tractor frame and cleaning that connection real well. It was corroded and pitting slightly. I polished the frame and the ring terminal then put some battery post terminal spray over the reassembled connection to keep it clean. It has worked fine since. I know that you stated you had voltage at the key switch, but have you pulled the bolt that connects the battery ground cable to the tractors frame to physically check that connection? It has been a consistent trouble spot that has caused instrument problems on these machines.
    "Contentment makes poor men rich, Discontent makes rich men poor." Benjamin Franklin
    "...The conflict between believers and non believers is not about the beliefs..." IslandTractor
  5. #15
    Join Date
    Feb 2007
    Posts
    225
    Pennsylvania
    Bobcat CT335SST
    Default
    Talked to the dealer yesterday.... I have a new ignition switch coming. After explaining about the electrical issues, we thought it was the main computer. If you wiggle the last plug under the hood closest to the main computer, the tractor will try and start! Short somewhere!
    The entire dash panel has been going nuts!! Turn on the 4wd, tach works, hit the brakes, the hour meter works but the tach will stop. It's crazy!
    I sure hope it's the ignition switch like they think it is or I'm up a ***** creek in a chicken wire canoe.
    S.F.
  6. #16
    New Member
    Join Date
    Sep 2013
    Posts
    4
    MIchigan
    Bobcat CT230
    Did the switch fix your issue?
  7. #17
    New Member
    Join Date
    Oct 2013
    Posts
    9
    Vancouver
    Bobcat
    I am having the same dash issues. My ct235 has no lights, hour meter,tachometer or temp guage. The tach comes on sometimes but as soon as I turn on the lights all the dash dies. Any answers?
  8. #18
    Gold Member
    Join Date
    Jul 2007
    Posts
    446
    Pennsylvania
    Bobcat
    So did anyone ever get their tractors fixed?
  9. #19
    New Member
    Join Date
    Oct 2013
    Posts
    9
    Vancouver
    Bobcat
    No. I called the dealer and he had no ideas other than to bring the machine to him. That involves a ferry ride, 1.5 hr drive and great expense. I have checked and replaced the battery terminals, checked cleaned and re attached the ground and no difference. The tach will come alive for short periods but when the lights are tried it dies immediately. With winter coming this is a real pain, especially with a tractor with less than 150 hours on it. Any ideas, or has anybody with the same issues found a fix.
  10. #20
    Gold Member
    Join Date
    Jul 2007
    Posts
    446
    Pennsylvania
    Bobcat
    I fixed mine this morning, found that the starter relay was bad. So far so good been using it most of the day with no issues. My relay was under the hood kind of on the firewall but mine is a CT450. When I grabbed the relay mine dash would come in and out, so I swapped it out with new one and its been good.
Similar Threads
  1. Loader B2320 Loader Issue?
    By maximus1277 in forum Kubota Owning/Operating
    Last Post: 09-04-2011, 12:36 AM
  2. Bolens 1468 G14XL steering issue
    By NewtoBolens37 in forum Projects
    Last Post: 05-13-2011, 06:53 PM
  3. new craftsman GT6000 Kohler eng issue
    By SPIKER in forum Craftsman / Sears
    Last Post: 05-10-2011, 09:09 PM
  4. T2310 Starting Issue
    By jonnykk in forum New Holland Owning/Operating
    Last Post: 11-25-2010, 11:06 AM
  5. Flail Mower Flail Mower Issue
    By Mike5252 in forum Attachments
    Last Post: 05-14-2008, 09:56 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
