I was having the same issue with my CT445, intermittent gauges and lights. I took the relays off the firewall and used some 320 sandpaper to clean the plug spades on the outside and opened up the relay and used the 320 on the relay contacts. Put them back on and everything has worked fine since then. No troubles!
Thanks to the advice from the guys on this board I have found the problem and fixed the issue with the dash panel instrument lights on my CT450. Some lights that should come on didn稚, others that should not come on did and the tach worked only intermittently. In the interest of simplifying life for other CT owners, here is my experience.
The problem was a faulty relay as many suggested, but which one? The problem was compounded by the fact that both the operation & maintenance manual and the repair manual contain a serious error in the discussion on relays.
There are four relays on the engine-side of the firewall. Both manuals have mislabeled the function of these relays. I discovered this after I replaced the relay labeled 妬gnition switch which didn稚 fix the problem. After hours of screwing around, I compared the wiring schematic to what the manuals said, and Eureka the problem leapt off the page. The manuals were wrong!
As others have pointed out, there are four relays on the engine side of the firewall. It is important that we all are talking about the same thing when we talk about right and left. The manuals label these relays from the tractor痴 right-side or YOUR LEFT SIDE AS YOU ARE FACING THE FIREWALL FROM THE FRONT OF THE TRACTOR.
Here is the correct order and function of the relays followed in parenthesis by the erroneous order listed in the manuals. The order is from your left side as you are facing the fire wall.
1. Pre-heat relay (ignition switch)
2. Starter relay (glow plugs)
3. Fuel pull relay (fuel pull relay)
4. Operating control unit -this is not a relay.
5. Switched power (timer). This is the relay that most likely is causing your problem.
