Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Silver Member krazsk's Avatar
    Join Date
    Oct 2009
    Posts
    200
    Bobcat CT225, McCormick X10.50H
    Default Bob tach 7TL vs. pin on
    Do any of you have experience with converting a 7TL (CT2XX series tractor loader) from pin on to Bob tach? What was involved and what did it cost? Any tricks or shortcuts? Aftermarket vendor? How do you convert the bucket from pin on to Bob tach?
    I really think I want to do it, but want to steal someone else's research and ideas and avoid someone else mistakes and regrets.
    Do you have any interesting new bucket attachments?
    Thanks,
  2. #2
    Join Date
    Jun 2009
    Posts
    625
    Nowhere
    1878 Ford 65N
    Default Re: Bob tach 7TL vs. pin on
    You can buy the QA parts from BC or get aftermarket ones. You can sell your bucket and buy a new one or weld a QA plate on your old bucket. There has been previous posts about this. Just search it out.
  3. #3
    Super Member
    Join Date
    Nov 2009
    Posts
    5,758
    Indiana
    Bobcat
    I still do not understand why people continue to buy the pin on system instead of the Bobtach.
    I do not even understand why Bobcat even continues to manufacture the pin on
  4. #4
    Join Date
    Oct 2009
    Posts
    200
    Canada, Actually I did search for this before I put the post up, and nothing jumped out at me. I tried Bob tach, and quick attach, and bobcat loaders, but do you have a hint on how to find the threads? I believe you that this has probably been answered or discussed before, but I didn't find anything when I looked. I apologize if the question was naive or ignorant.
  5. #5
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,182
    Branson, Mo.
    Kioti DK35se Hydrostat
    Quote Originally Posted by krazsk View Post
    Here is my thread in converting a kubota to QA..Don't let the first part of the thread dissuade you from doing this. I would do it again, and was thinking about actually doing it to gain another bucket.
    http://www.tractorbynet.com/forums/c...rting-pin.html
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  6. #6
    Join Date
    Jun 2009
    Posts
    625
    Nowhere
    1878 Ford 65N
    Yup, search in the Kioti forums too. That is probably where I saw it.
  7. #7
    Elite Member SSdoxie's Avatar
    Join Date
    Jun 2010
    Posts
    2,527
    Cumberland Plateau, TN
    Bobcat CT225
    I switched 7TL over to Bobtach. I ground the pin plates off the old bucket and welded on a pre-made mounting frame. Only thing to be aware of if yours is Rhino built loader and bucket, the top of the mounting frame sets up about 6" higher than the vertical back of the bucket. I welded a couple pieces of angle from the top of the mounting frame to the bucket to give it a little extra support and makes nice spot for hooking a chain. (photo attached) The Bobcat built bucket has a taller back so the mounting frame will fit better. If not sure what bucket you have look at the holes in the cutting edge, if there a 2 rows of holes along the front lip of the bucket it is a Bobcat bucket and only 1 row it is Rhino bucket. The same Bobtach fits both the Rhino & Bobcat built loader.
    You may want to contact Rick Wallace on here. Someone else asked this same question a couple months ago and Rick quoted him what I thought was a very good price on the Bobtach and new bucket.
    Attached Thumbnails Attached Thumbnails Bob tach 7TL vs. pin on-img_0019-1-jpg
    Dennis
    CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
  8. #8
    Join Date
    Oct 2009
    Posts
    200
    thanks doxie, did you get the conversion kit from Bobcat? Do you remember what it costs? The top of your bucket looks pretty familiar.
  9. #9
    Join Date
    Jun 2010
    Posts
    2,527
    Bobcat CT225
    I bought mine from the dealer last year. List price is over $700, probably closer to $800 now but I got a lower price since I wasn't in big hurry and they ordered it on stock order so no freight charges. I also bought the mounting frame from them at same time. I don't know what, if anything, is available in and aftermarket that fits this loader. I like the Bobcat one, it comes with new pivot pins and width between the cylinder holes is spaced to allow the bucket level indicater fit.
    Dennis
  10. #10
    Member
    Join Date
    Mar 2011
    Posts
    33
    Massachusetts
    kubota b2620 TLB
    Krazsk W.R.Long makes a after market adaptor plate to convert from pin on to bob tach. They can make one for almost every make of tractor you can think of. The web sit is www.wrlong.com
Similar Threads
  1. Power bob tach
    By MrJimi in forum Build-It Yourself
    Last Post: 10-22-2007, 10:12 AM
  2. Tilt tach problem with Bobcat bucket
    By k6dyc in forum Toolcat
    Last Post: 09-09-2007, 04:35 PM
  3. JINMA 204 (2004) Tach wiring ??
    By DirtPoor in forum Chinese Tractors
    Last Post: 10-04-2004, 08:54 PM
  4. TC33D Tach
    By GAF in forum New Holland Owning/Operating
    Last Post: 06-10-2003, 08:55 AM
  5. Tach for Deutz engine
    By Bob999 in forum Power Trac
    Last Post: 05-30-2003, 10:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
