Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Jul 2009
    Posts
    12
    Chesapeake Va.
    Bobcat CT 235
    Smile Is the new Bobcat backhoe a 3 pt. attachment?
    Does any one have a new Bobcat back hoe out there? The new ones on the Bobcat web page look like 3 pt. hitch attachments instead of the frame mounted original units. If so , are they less expensive ? Are they less sturdy? and are they easier to attach?
    Thanks in advance for the info.
    oldguy
    Bobcat 235
  2. #2
    Elite Member SSdoxie's Avatar
    Join Date
    Jun 2010
    Posts
    2,514
    Cumberland Plateau, TN
    Bobcat CT225
    Default Re: Is the new Bobcat backhoe a 3 pt. attachment?
    The backhoe is still the same sub-frame mounted.
    Dennis
    CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
  3. #3
    New Member
    Join Date
    Apr 2009
    Posts
    15
    Default
    I have one and it works well. It still has the sub frame, but it also has the holes to be installed as a 3pt mount. I have never used it has a 3pt mount however. Once you get used to the sub frame mount, it can be changed in about 10 minutes. I previously has another brand 3pt mount back hoe and it was a pita to take on and off. It could be don't in 30 minutes when the stars were all aligned and 2 hours when they were not. It had a pto pump on it however. I like my bobcat much better. Plus you can use more of the weight of the tractor when digging.
    Sent from my iPad using TractorByNet
    Joe
    Bobcat CT230 with FEL and Backhoe
    Lenar 274-1
    Southern IN and Eastern TN
    Most the work is done in Eastern TN.
  4. #4
    Platinum Member familyman's Avatar
    Join Date
    May 2004
    Posts
    592
    Perkiomenville, Pa
    Kubota L2800DT
    Believe it or not, I asked a dealer that same question this morning, because the Bobcat website says "3-pt. backhoe".
    He said they are indeed subframe mounted.
    Whatever you do, DON'T get a 3-pt. mounted backhoe. Subframe mount is much stronger and much more convenient for on-off.
    Kubota L3800HST, LA 463 FEL, Woods BH80-X backhoe, Befco 6' BB, Woods RM59, Woods LR72
    I work, therefore I am.
  5. #5
    Member
    Join Date
    May 2010
    Posts
    29
    I just got a quote on a 7TL BACKHOE FROM bOBCAT. iT IS $9000 for the hoe, subframe and 2 remotes. I am going to go and look at one this week because I have never seen THE Bobcat backhoe. I think that I am going to pull the trigger and get it. I was going to get a woods 80BH but the quote was $10,600 plus 2% of financed ammount. That was too much for me.
  6. #6
    Super Star Member
    Join Date
    Oct 2004
    Posts
    16,854
    First organized permanent settlement in the northwest territory
    2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
    Post Re: Is the new Bobcat backhoe a 3 pt. attachment?
    Quote Originally Posted by Mike Fortner View Post
    Is A 3 pt. less sturdy?
    Yes and they are more dangerous .
    There have been incidents of people getting crushed to death between the BH and the ROPS when the 3 point fails.
    Tractors 2003 Kubota BX1500 / 2004 Kubota Bx23 / 2005 Kubota BX1500.
    Attachments 60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /
    60'' MMM/Clamp on Forks/48'' MMM
    South of Canton Ohio L .B
  7. #7
    Silver Member SABULA FARMER's Avatar
    Join Date
    Feb 2007
    Posts
    225
    Pennsylvania
    Bobcat CT335SST
    Is the new Bobcat backhoe a 3 pt. attachment?-img_1404-jpg
    I have a 8tl backhoe attachment. I just got it maybe two months ago....great digger for sure, and yes its subframe mounted.
    I am putting it up for sale though, too big for what I need....
    ...I have all the answers, can you wait a minute while I ask my wife?
    2010 Bobcat CT335, 5' King Kutter Hog, 5' Bush Hog Finish Mower, 14" 2 Bottom Plow, 6' V Discs, 8' Chain Link Harrow, 7' Bush Hog Back Blade
Similar Threads
  1. sweeper attachment for Bobcat
    By avz in forum Attachments
    Last Post: 03-29-2012, 10:08 AM
  2. Bobcat 905B backhoe attachment
    By Renze in forum Construction Equipment
    Last Post: 10-03-2011, 04:53 AM
  3. So... what attachment your Bobcat got this week...
    By NOTV8 in forum Bobcat Tractors
    Last Post: 10-05-2010, 09:25 PM
  4. Bobcat backhoe attachment
    By 1grnlwn in forum Bobcat Construction Equipment
    Last Post: 09-29-2010, 07:36 PM
  5. PT attachment on Bobcat
    By BillCroasmun in forum Power Trac
    Last Post: 03-31-2006, 12:30 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
