Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
  1. #11
    Gold Member pwright's Avatar
    Join Date
    Aug 2012
    Posts
    386
    San Antonio, NM
    2012 Bobcat CT225
    Default Re: Snow Plow
    Great feedback. Thanks guys!
    I'll have to look around and see what is available.
    Phil
    Bobcat CT225 with FEL and Bobtach.
    Landpride box blade, post hole digger and pallet forks.
  2. #12
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,269
    Central Ohio
    Kubota MX5100
    Dont worry about the loader arms. I am not saying that it "cant" happen. But it is unlikely. People do it everyday, and have been for years without issues. Properly set-up, with the springs and a crossover relief, you have nothing to worry about. You are just pushing snow. Its NOT a dozer blade, and dont require arms and a frame built like one either.
    And like wallace said, when pushing into a pile of dirt or gravel, its the same thing. In fact (and I am sure I am not the only one) there have been SEVERAL times when I DIDNT want a full bucket. Like say filling just a rut or pothole, and dont want to dump 5' wide path of material, I will go into the pile at an angle JUST to fill one corner of the bucket.
    And what about when you are digging with it and catch a tree root or something on only one side?? That puts way more side force than an angled snowplow.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  3. #13
    Platinum Member catdozer's Avatar
    Join Date
    Sep 2011
    Posts
    510
    Indiana
    Bobcat CT235
    Default
    Really if you can go with the loader mounted great. But I was just saying that i couldn't get it pushed back off far enough that it "throws" my tractor around. That I want the plow closer to the tractor.
    Bobcat CT235 with Deere Imatch, And a very bad addiction of attachments
  4. #14
    Elite Member Rustyiron's Avatar
    Join Date
    Mar 2011
    Posts
    4,253
    Lakes Region, Maine
    M 9540 Kubota
    One problem with a loader mounted plow is that it is so far forward, (of the front axle) especially angled. that there is a bunch of leverage pushing the front out of the snow, esp. a deep or wet/heavy snow, driving (steering) will be up to the snow not you. This creates the forces that others have described (with a blade mounted plow) and may not be the best for your loader arms.
    Attached Thumbnails Attached Thumbnails Snow Plow-16-jpg
  5. #15
    Join Date
    Aug 2012
    Posts
    386
    San Antonio, NM
    2012 Bobcat CT225
    Well I am in New Mexico and even though my property is up at 5000+ feet any snow there is pretty unusual. What does happen, once every couple years, is that we'll get a couple inches of snow that is accompanied by strong winds and then we get these big drifts on the roads that typical 4WD jeeps and trucks can't get through. Even lifted vehicles with aggressive tires often won't be able to get through them. By the following day most of the roads are clear, if muddy, but the drifts will hang around for a week or more. That's what I'll need to deal with. The drifts that accumulate in the shady spots and don't melt away within a day. I can probably just use the bucket as the drifts will be 10-15 yards long and then a quarter mile of mostly clear dirt road. Given that the roads are dirt and rock that may be the better choice rather than tearing up an actual snow plow.
    Phil
  6. #16
    Join Date
    Apr 2008
    Posts
    18,269
    Central Ohio
    Kubota MX5100
    With skid shoes, trip springs, and a crossover relief, the odds of damaging your plow, even on a rock road, are slim.
    But given what you just said, and it frequency and quantity of plow time you will need, I think you are right to just stick with the bucket. It'd probabally take you longer to throw the plow on than to just use the bucket and be done.
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  7. #17
    Join Date
    Aug 2012
    Posts
    386
    San Antonio, NM
    2012 Bobcat CT225
    Yeah, I think I'll see what happens this winter but keep an eye out for any deals on quick-detach snow plows. If this winter is like last and I do end up dealing with some drifts I'll find out real quick how it goes with the bucket.
    Phil
  8. #18
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    If you rarely have snow could you move it with a scraper blade and bucket?
  9. #19
    Join Date
    Aug 2012
    Posts
    386
    San Antonio, NM
    2012 Bobcat CT225
    Quote Originally Posted by 94BULLITT View Post
    That's the plan for this winter. If it isn't doable or takes too much more work than with a plow then I'll find a plow.
    Phil
  10. #20
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default
    You could get a truck plow and convert it.
Similar Threads
  1. Non-stick spray for snow plow/snow blower?
    By JonKioti in forum Kioti Owning/Operating
    Last Post: 11-24-2012, 01:16 PM
  2. Snow V Snow Plow
    By MossRoad in forum Power Trac
    Last Post: 02-11-2010, 04:54 PM
  3. Snow Attachments Snow Plow or Snow Pusher???
    By Brokermike in forum Snow Removal
    Last Post: 10-17-2009, 12:26 AM
  4. Snow Equipment Owning/Operating Plow Snow? In Michigan, we plow mud!
    By Raddad in forum Snow Removal
    Last Post: 01-08-2007, 06:28 PM
  5. Snow Attachments FEL mounted snow plow in deep, wet, heavy snow?
    By bam747 in forum Snow Removal
    Last Post: 11-09-2006, 12:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
