Results 21 to 30 of 35
01-21-2013, 02:15 PM #21
Re: CT122 electrical gremlin
hmmmm, thanks for the tip k0ua, I'll have to look into it
01-21-2013, 02:36 PM #22
- Join Date
- Dec 2012
- Posts
- 52
- Location
- Orillia Ontario
- Tractor
- 50&51 8N Ford
Hi I'm not real familiar with Bobcat but if it's similar to the older small massey ,my neighbours was acting the same & ended up to be a blown fuse ,because the starter wiring at the side of the engine had rubbed through & shorted out on the block.the fuse was in a holder which was in line ( plastic sheild with wires going in & out ) under the hood just behind the engine. Good Luck Bruce
01-21-2013, 03:18 PM #23
I'll have to look into that as well, thanks!
01-21-2013, 05:17 PM #24
well, you guys saved me $300. Thank you!!!! I got home from work and went to hook up the battery to do some more tests, and the positive cable crumbled in my hand!!! I can't believe that such a thing could happen after such a short time, but the clamps are made out of sheetmetal or some other crappy thin material. I'm surprised I didn't notice it the other evening when I took the battery out. I'll be taking the cable back to Bobcat for warranty but I'm not sure I even want to put a new one of the same quality on. I'm thinking of getting a marine cable made up, with tinned wire and high quality ends.
Here is what I'm working with, for those who like pics:
01-21-2013, 10:58 PM #25
- Join Date
- Jun 2009
- Posts
- 28,146
- Location
- Branson, Mo.
- Tractor
- Kioti DK35se Hydrostat
yep, that is what I was talking about. Greenish/whitesh "mung" what ever you get to replace it with. get some of this and coat everything metal on the cable clamp, battery post, and push it into the strands of wire in the cable if possible, and cover any exposed metal part of the cable with a good coating of this stuff, and your problems will never return..
Amazon.com: no-ox-id a-special
James K0UAJames K0UA
Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
01-22-2013, 12:01 AM #26
- Join Date
- Jun 2009
- Posts
- 28,146
- Location
- Branson, Mo.
- Tractor
Here is another possible place to buy it..
Sourcetel Supply - Telecom material supplyJames K0UA
01-22-2013, 03:16 PM #27
Thanks everyone for your help!!! I went to Bobcat today and they wanted $50 for a new positive cable and in order for it to be covered under warranty they needed me to haul my tractor an hour away to them. Instead, I went to the auto parts store and bought a positive cable for $9 and some loom to protect it. I'm happy to say that the tractor started right up!!!
I'm going to order some of that corrosion protectant that k0ua recommended but I think that the lead end will be much sturdier than the cheapo potmetal end that bobcat originally provided!
01-22-2013, 05:08 PM #28
- Join Date
- Oct 2009
- Posts
- 2,097
- Location
- Jefferson County, Mo, ... about 35 miles out of St. Louis.
- Tractor
- Bobcat 235, Gravely ZTR.
My goodness. The Bobcat dealer sure didn't act very helpful on this issue. That is terrible.
MoKelly
01-22-2013, 09:23 PM #29
01-23-2013, 10:33 PM #30
- Join Date
- Mar 2005
- Posts
- 1,860
- Location
- Erie, Pennsylvania
- Tractor
- Kioti CK30HST
I've used NOCO corrosion spray and those felt pads soaked in the stuff for over 30 years when I learned of it from working in a garage. I've never had cable clamps corrode. Here's a site and amazon sells the stuff to if you buy there. Just something known to work and probably similar to what K0ua mentioned. NCP-2 Battery Corrosoion Preventative - All Battery Sales and Service
Vic
2004 Kioti CK30hst, KL130 fel, KB2375 bh
Similar Threads
JD 6320 Electrical Gremlin
By Tippett in forum Owning/OperatingReplies: 0Last Post: 10-01-2012, 01:19 PM -
Electrical Gremlin
By Iplayfarmer in forum Parts/RepairsReplies: 8Last Post: 06-26-2012, 12:32 PM -
4720 Cab -Electrical Gremlin
By Red Horse in forum John Deere Owning/OperatingReplies: 2Last Post: 03-01-2012, 09:32 AM -
Electrical Gremlin
By GBHRPS in forum Cub Cadet L&GReplies: 4Last Post: 08-18-2011, 07:18 PM -
I have the intermittent instruments gremlin
By Texwing in forum Kubota Lawn & GardenReplies: 25Last Post: 03-08-2011, 10:22 PM
