Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
  1. #11
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,816
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    Default Re: Hydraulic Toplink Hoses
    Quote Originally Posted by MtnViewRanch View Post
    Complete top Link kit, cat 1-2, 3" dia cyl, 1 1/2" dia rod, 12" stroke, 23"-35" working length with hose kit and flow restrictor, all for only $335 + shipping cost to your zip code.
    Thanks, I will probably be getting in touch with you in the next month or so.
    "In theory, there is no difference between theory and practice. But in practice, there is." - Yogi Berra
  2. #12
    Silver Member BelarusBulldog's Avatar
    Join Date
    Aug 2011
    Posts
    135
    The ROCK! NL. Canada
    Belarus 562 / Bobcat CT122 / Kubota BX1860 / Honda HT4213
    Quote Originally Posted by catdozer View Post
    How do you run your hoses for your toplink? I cant seem to get a good configuration to set the hoses, it works one way but not the other. If you can pist how you have then that would be great, heres an old photo i currently run them under and back up to the couplers
    I haven't had any issues running them this way.
    Attached Thumbnails Attached Thumbnails Hydraulic Toplink Hoses-dsc04283-jpg   Hydraulic Toplink Hoses-dsc04284-jpg   Hydraulic Toplink Hoses-dsc04285-jpg
    Plowing, it's snow much fun!
  3. #13
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    That's the way Brian said to do them, Pointing towards the implement.
    Murph
  4. #14
    Silver Member blake037374's Avatar
    Join Date
    Jan 2013
    Posts
    118
    Baton Rouge, LA
    CT440
    Default
    Quote Originally Posted by BelarusBulldog View Post
    Where did you get that top link from? Is that from bobcat?
  5. #15
    Super Star Member ovrszd's Avatar
    Join Date
    May 2006
    Posts
    16,759
    Missouri
    Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
    As mentioned above, smaller diameter hoses will put less stress on the fitting ends when it's bent double. Here's a pic of mine with 3/8" hoses. 18" and 30" hoses. That length would be dependant on what tractor you are using and the location of your remote couplers.
    Richard
    "Happiness isn't having everything you want, it's wanting everything you have."
  6. #16
    Join Date
    May 2006
    Posts
    16,759
    Missouri
    Do you remove your hydraulic top link if using your PTO??
    Richard
  7. #17
    Join Date
    Aug 2011
    Posts
    135
    Quote Originally Posted by ovrszd View Post
    Sorry I took so long to answer. No I leave everything as is, even when using my tiller. Just take it off when mounting the backhoe.
  8. #18
    Join Date
    May 2006
    Posts
    16,759
    Missouri
    No worries. From the pics it looks like the hoses would be laying on the PTO shaft. Just wondered how you prevented that. Thanks.
    Richard
  9. #19
    Join Date
    Aug 2011
    Posts
    135
    My PTO shaft is inside of a plastic tube, so no rubbing issues.
  10. #20
    Join Date
    May 2006
    Posts
    16,759
    Missouri
    Yep, I getcha, would kinda freak me out though.
    Richard
Similar Threads
  1. 3-Point Hitch Hydraulic Toplink
    By pedalstomper78 in forum Case-IH
    Last Post: 02-15-2011, 11:45 AM
  2. Toplink Hydraulic toplink question
    By Tact in forum Attachments
    Last Post: 10-18-2007, 03:39 AM
  3. HYDRAULIC TOPLINK
    By flINTLOCK in forum New Holland Owning/Operating
    Last Post: 03-25-2007, 01:18 PM
  4. Hydraulic Toplink?
    By slinger in forum Kubota Owning/Operating
    Last Post: 06-10-2006, 07:55 PM
  5. Hydraulic toplink for 2615
    By AchingBack in forum Mahindra Owning/Operating
    Last Post: 06-04-2006, 03:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
