Results 1 to 8 of 8
  1. #1
    Gold Member Trails End's Avatar
    Join Date
    Jul 2012
    Posts
    304
    Candia, NH
    Bobcat CT335
    Default Bobcat CT335 Mid-Mount PTO
    Hello again!
    Life is full of surprises. I purchased my CT335 just a year ago, and though I didn't order this option,
    I just discovered that it has a mid-mount pto. See attached photos. The only things that are missing
    are the mid-mount pto engagement lever beneath the seat and the pto shaft cover. The newly discovered
    pto does work but I just will not be able to dis-engage it to use just the rear mount pto.
    MY question is: Is it possible to add the mid-mount pto engagement lever myself, assuming that I can get
    that assembly from the dealer? I'll be checking with my dealer tomorrow, but thought I'd throw out the
    question to forum readers for their comments.
    Attached Thumbnails Attached Thumbnails Bobcat CT335 Mid-Mount PTO-182657-jpg   Bobcat CT335 Mid-Mount PTO-182515-jpg
    Best Regards from Candia, NH
    Bobcat CT335, 8TL FEL with 68" bucket, EverythingAttachments 72" boxblade
    Bobcat 72" Snow blade, WR Long OBG2-48 Grapple, Pronovost Puma-74 snowblower
    Everything Attachments ETA-CMP-LR-84 Landscape Rake
  2. #2
    Elite Member SSdoxie's Avatar
    Join Date
    Jun 2010
    Posts
    2,514
    Cumberland Plateau, TN
    Bobcat CT225
    Default Re: Bobcat CT335 Mid-Mount PTO
    Shouldn't be too hard to install. The pivot mount for the control lever is already on the frame under the seat, just a matter of installing the arm and attaching the linkage rod from control lever to the bell crank (control arm) going into the transmission. This bell crank is also installed at factory.
    Dennis
    CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
  3. #3
    Join Date
    Jul 2012
    Posts
    304
    Candia, NH
    Bobcat CT335
    Hi Dennis!
    Thank you for your response to my query on mid mount pto on my CT335
    tractor.
    Do you have part numbers for the components needed to install the mid-
    pto lever and linkage? I purchased the CT335 service manual, thinking
    that installation details would be included in the manual, but only the
    procedure for removing or installing the mid-pto lever is in the manual,
    with no details on the linkage from the lever to the bell crank on the side
    of the transmission.
    Any help will be greatly appreciated.
  4. #4
    Join Date
    Jun 2010
    Posts
    2,514
    Bobcat CT225
    Quote Originally Posted by Trails End View Post
    Hi Dennis!
    tractor.
    Sorry for the delay. Due to family emergency I have been off line for sometime.
    This link will take you to the Bobcat Parts Catalog. Scroll down on the tab to select your model & serial number, then "GO". Choose "Accessories" the Mid PTO kit to see parts illustration page. You will need items #29 - 41. Bobcat dealer should be able to print the instructions for you.
    BASSII - Bobcat Company
    Dennis
  5. #5
    Join Date
    Jul 2012
    Posts
    304
    Candia, NH
    Bobcat CT335
    Thanks, Dennis!
    I've tried that link but all I get is an incomplete page with the notification:
    Notifications
    *Contact your local Bobcat dealer for pricing and purchasing of Bobcat products & parts listed on this site. We do not sell parts from this site and do not have access to pricing and availability information.
    No provision for selecting a model number and/or serial number.
    I'll eventually get up to my dealer. Haven't made it up there yet due to problems with my vehicle,
    which is back in the garage for an engine problem.
    Again, thanks for the information. At least I now know that I need items #29 - 41 on the mid-pto
    kit parts illustration page.
  6. #6
    Join Date
    Jun 2010
    Posts
    2,514
    Bobcat CT225
    ct335 mid pto kit.pdf
    Here is the part illustration from that page link. Prices are not listed and you cannot order direct from Bobcat. This will give you part numbers needed if dealer can't figure out what you need.
    Dennis
  7. #7
    Join Date
    Jul 2012
    Posts
    304
    Candia, NH
    Bobcat CT335
    Thanks, Dennis! That's just what I need. I'll feel more comfortable having this information when
    I get to the dealer.
  8. #8
    Join Date
    Jul 2012
    Posts
    304
    Candia, NH
    Bobcat CT335
    As a side note, I just discovered why I couldn't access the Bobcat parts catalog, since
    I was using the Firefox browser. I switched to IExplorer and was then able to access
    the information for the mid pto kit.
    Again, thanks Dennis for your assistance.
Similar Threads
  1. JD 4300 Mid Mount Mower Availability
    By Chef Pa in forum John Deere Owning/Operating
    Last Post: 05-06-2013, 02:16 PM
  2. Adding mid PTO to 3320
    By snohobigdad in forum John Deere Owning/Operating
    Last Post: 05-04-2013, 01:04 AM
  3. Replies: 4
    Last Post: 05-03-2013, 07:29 PM
  4. Bobcat CT335
    By Pierrepont in forum Bobcat Tractors
    Last Post: 03-24-2013, 11:57 PM
  5. BOBCAT CT335
    By MATTS875 in forum Bobcat Tractors
    Last Post: 06-01-2010, 08:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
