Results 1 to 3 of 3
  1. #1
    Platinum Member Lockport's Avatar
    Join Date
    May 2004
    Posts
    779
    Lockport, Manitoba
    Bobcat CT235
    Default Now what? !?!
    It seems the hole drilled into the base of the support mount of the auger gearbox that is intended to align with the drain plug on the FCTSB72 (front mount snowblower) is nowhere near accessible alignment. Gear oil change will now involve extensive labor.
    Attached Thumbnails Attached Thumbnails Now what? !?!-forumrunner_20130522_173419-png   Now what? !?!-forumrunner_20130522_173655-png
    New...
    Bobcat CT235
    72" RFM, 72" SB, 7TL Loader & 7TB Backhoe
    60" Worksaver Box Blade
    48" Tebbens Bush Hog
    25 Gal 10' 3PH Sprayer
  2. #2
    Join Date
    Sep 2006
    Posts
    105
    lancaster ny
    bobcat ct122
    Default Re: Now what? !?!
    if its close I would use a carbide burr on a die grinder and REALIGN the hole
  3. #3
    Elite Member SSdoxie's Avatar
    Join Date
    Jun 2010
    Posts
    2,530
    Cumberland Plateau, TN
    Bobcat CT225
    Is the blower still in warranty? Less than year old? If so let the dealer take it apart and get bracket with hole in correct spot or make a new hole.
    Dennis
    CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
