Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    Gold Member
    Join Date
    Apr 2009
    Posts
    401
    Rushville, IN
    Bobcat CT230
    Default CT230 w/ 3 bottom plow?
    Anyone using a 3 bottom plow with their CT230? I picked up a real nice Ford 3 bottom at an auction a few weeks ago and I am dying to try it out. Unfortunately, it is still too wet and still a little frozen underneath I think. I should add that I beleive it is a 3-14 if I measured correctly.
    I feel pretty confident that I can pull a two bottom but three bottom I am not sure. The third bottom is easy enough to take off but I would like to try it first.
    Bobcat CT230, Woods BH80-X Backhoe, Caroni 72" finish mower, County Line 60" tiller, 72" United Boxblade, 72" County Line rotary mower, Quick hitch
  2. #2
    Super Member newbury's Avatar
    Join Date
    Jan 2009
    Posts
    9,135
    From Vt, in Va, retiring to MS
    Kubota's - B7610, M4700
    Default Re: CT230 w/ 3 bottom plow?
    I got a 1 bottom (mainly for my B7610) and could just about stall my M4700 (w/ loaded rears) in moist clay.
    from elsewhere:
    Quote Originally Posted by schmism View Post
    rule of thumb (brush hog 5hp er foot of width) for bottom plows its about 15hp per plow. 12" take less, 18" take more.
    my 33hp hydro just squeeks out my 2x16 Dearborn. A 2x16 was the standard 2 bottom matched with a 30hp tractor from the 60's
    so the 15hp stands up from a number of data points.
    so 3bottom ~45hp which is why 60hp tractor pulls a 3bot fine.
    Search is your friend.
    You might want to drop one of the three blades.
    My rides - '95 Kubota M4700 w/ PEC, LA1001 FEL :'07 B7610, LA352 FEL, Bush Hog SBX 48 box blade, '09 Woods BH70-X w/ 16" bucket and thumb, 3pt pallet forks, Dale Phillips PHD, Jinma 8" chipper, 2 Piranha's, Winco 12KW PTO generator, Howse plow, 5' KK tiller, 5' Big Bee cutter, with a 2002 7.3L Ford F350 CC DRW 4x4 and '07 18' Hudson HSE Deluxe trailer - 5 Ton to haul it all
    My saws - 12" B&D 40 volt,JD CS 62, efco 3500, Stihls - 021, 660 w/woods mod, 660 w/ DP muffler, 088, Woodmizer LT10
  3. #3
    Super Member smstonypoint's Avatar
    Join Date
    Oct 2009
    Posts
    6,841
    SC (Upstate) & NC (Piedmont)
    NH TN 55, Kubota B2320 & RTV 900, Bad Boy Outlaw ZTR
    Here's some info on estimated drawbar HP requirements for various implements: http://archive.lib.msu.edu/DMC/Ag.%2.../PDF/e1152.pdf. From Table 2, the estimated DBHP requirements per foot of moldboard plow width plowing at at an 8" depth are 5.4 in sandy soil, 9 in loam soil, and 12.6 in clay loam soil. These estimates are for ag. tractors -- I suspect that the DBHP requirements may be higher for lighter CUTs.
    Steve
  4. #4
    Elite Member motownbrowne's Avatar
    Join Date
    Dec 2013
    Posts
    2,635
    river falls, wi
    Kubota mx4700 HST, New Holland TC-29D
    Do you, like most cut owners have r4 industrial tires? If so, you might not even be able to pull 2 14s. With r1s and some weight up front, 2 should be fine. I really doubt your ability to pull 3.
    Okay, looked up some specs. I think you should either make it a two bottom, or buy a farmall m. The m is designed to pull a 3-14, and they cost about 2k around here. They weigh about 5k and have more power at the engine than your bobcat. Also, being geared vs hydro, they have way more power at the drawbar. If you try pulling it, don't overheat your hydro. Plowing isn't their strong suit, and that's way more than it's designed to pull.
    Do you have any experience plowing? How much land are we talking about? I'd probably recommend a single bottom for most compact owners. They are much easier to set up and get good results with. You could even pull it with r4s.
    Good luck.
    Kubota mx4700, New Holland TC-29D
    Mostly I grow vegetables. I get to make firewood too, but not as much as I'd like. And if I'm really lucky, I get to make some maple syrup.
  5. #5
    Platinum Member Daver1963's Avatar
    Join Date
    May 2013
    Posts
    831
    Idlewild, Tn
    Kubota L2800DT w/LA524 FEL, Cub Cadet XT1
    I have a 2 x 12 Ferguson plow on my L2800 (30hp). Just did some plowing the other day. It was about the right combo. I wouldn't want a 2 X 14 let alone a 3 X14.
    DaveR
    If a wire wasn't shorted it wouldn't work. What you have is an intermittent open!
    Electronics is smoke and magic. If you let the smoke out of something it doesn't work anymore - the magic is getting the smoke back in.
    County Line 6ft finish mower, King Kutter 5ft bush hog, King Kutter 4ft tiller, King Kutter Carry-All,
    King Kutter 60" Box Blade, Ferguson 12-AO-40 2-bottom plow, County Line Middlebuster, Home built pine needle rake.
  6. #6
    Gold Member
    Join Date
    Apr 2009
    Posts
    401
    Rushville, IN
    Bobcat CT230
    Thanks guys. I do have the r4's on mine because I also mow with it and they do a nice job of not tearing up the yard.
    I gave it a try last night even though it was still a little wet outside. I was able to pull it until I hit a really wet spot, then it just stopped me and I spun out. Our soil has a little bit of a sandy/rocky mix to it and the place I was plowing had been tilled about 2" last year. I did not measure the depth but it looked like a good 8-9" deep on the pass I made before I got stuck. I have not done any setup on it since i bought it.
    That being said, I will probably pull the third bottom off in case I need to plow some ground with a harder soil. I have some guys that are going to put food plots in for deer and quail this year so I am not sure what we will be plowing.
    The plow sits really tight up towards the back of my tractor, too close. It hits on my 3pt arms. I was hoping to use it with my quick hitch but the lever on the right hand side that adjusts the tilt of the plow interferes with the QH. I am going to try to figure out a way to make it work with the QH but not sure exactly how yet. I hate having to try to hook something up after using the QH.
  7. #7
    Join Date
    May 2013
    Posts
    831
    Idlewild, Tn
    Here are some helpful instructions on plowing. They are for a Ferguson plow, but the concepts are good for any plow.
    Plowing Procedures (6 pages)
    DaveR
  8. #8
    Gold Member
    Join Date
    Apr 2009
    Posts
    401
    Rushville, IN
    Bobcat CT230
    Thanks Dave, I will look at that tonight. I had someone send me some scanned pages from the Ford plow on how to set it up. I can comapre the two.
    By the way, what are all you kubota people doing hanging out on the Bobcat forum? I posted on here expecting to get real life experience from the BC folks and no one person that has a BC responded. This used to be a very active forum but no so much anymore. I don't stop by as often. Maybe you Kubota owners have ran everyone off!
  9. #9
    Join Date
    May 2013
    Posts
    831
    Idlewild, Tn
    Instead of visiting every forum I usually look at "Today's Posts" and "New Posts" as it shows the newest or most active threads going on. I suspect many others do the same thing.
    DaveR
  10. #10
    Join Date
    Dec 2013
    Posts
    2,635
    river falls, wi
    Quote Originally Posted by Daver1963 View Post
    Yep. Same here. Sorry if we ran everyone off. I wonder if most bobcat owners spend time on the kioti forum, since they made the tractors anyway.
Similar Threads
  1. Replies: 4
    Last Post: 12-16-2012, 09:30 AM
  2. Two-bottom plow always two-bottom?
    By maps in forum Attachments
    Last Post: 04-10-2011, 05:30 PM
  3. Snow New CT230 & snow plow w/PICS
    By Workaholic in forum Bobcat Tractors
    Last Post: 11-29-2009, 03:56 PM
  4. Dearborn 2 bottom, now a 1 bottom plow ready to roll!
    By yeagisyeag in forum Attachments
    Last Post: 04-16-2009, 05:23 PM
  5. Making a 2 bottom plow into a 1 bottom plow?
    By ky_madman in forum Attachments
    Last Post: 02-08-2009, 07:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
