lstinthot
Is there a way to troubleshoot what is causing my tractor from not moving like it should? From day one I could only use high gear on flat land, I would only use it when moving from one area of yard to other when not doing work. Now middle range is acting the same way. Tractor will not move if there is any kind of incline and definitely not move if I am trying to move dirt. I have to use low gear to do any kind of work. I use to be able to work all day in mid-range and only use low gear if I want to dig into a pile of dirt.
I have a hydrostatic CT-230 with about 300 hours. Hydraulic oil changed at 50 hours. Oil topped off a few hours ago.
All the other hydraulics seam to be working fine. I have rear remotes that drive the backhoe and the backhoe seams to be be working fine. I have tried turning the rear remotes off and it does not affect the drive capability.
Any ideas would be greatly appreciated.
