Thanks for your reply. Let me make sure I understand, you are taking about installing the rear remote auxiliary hydraulic kit and using it to run hydraulics to the Front of the tractor without buying the 3rd function kit with the push-button function? I think the Aux Kit from Bobcat comes with a detent but i'll ask the parts guy for sure.
Rick at EA replied to my inquiry: "If our 3rd function can’t work, we can build a selector valve, same type of kit, with a center button to depress, when you use the loader circuit, and then, back to normal loader operation, it is not inconvenient… I can confirm… Thanks,"
The message from W.R. Long said: "If anything they may just have to have a different hose made going from the my “T” port back to their 3 point hitch. Long story short, as long as my valve is tied in before their 3 point hitch they will be fine."
Under the circumstances I would rather run the Grapple from the Rear Aux and use a lever to open and close. I don't want to mess around with interrupting the hydraulics to the 3-point system.
Thanks Jabonee, If you have any further advice I would appreciate you sharing it.
