Lockport
It was running, no pto, I set the brake got off the seat and it started to stall. I sat down it kept running, I got off again it started to stall and I sat down, it kept running. Verified the brake was set, it was. Got off, it stalled, got back on and it won't turn over. Turn the key, the solenoid "clacks" but nothing. Tried swapping the relays on the firewall. No effect. Any suggestions?
Further: seems it "clacks" if I'm not in the seat and won't crank as expected. But if I'm in the seat, a muffled "frump" is heard upon ignition. And if I get out of the seat, I hear the loud "clack" but it still won't turn over.
Conclusion: debris in the hydro pedal safety micro switch is interrupting the start command. Clear the blockage and assure the hydro pedal centering is closing the contact. You should hear a little click.
