Wild and Free
- Joined
- Oct 13, 2017
- Messages
- 91
- Location
- New Salem ND
- Tractor
- Bobcat Ct 450 with 9tl loader and 7' 730 lorenz snowblower, 7' Road Boss utility grader
So I have been told by the previous owner and was reinforced by the dealer that these tractors are notorious for snap rings that break and cause front axle gear failures on the wheel final drive assembly. Does anyone know which snap ring breaks on these? I was told by the previous owner that he had a recent failure and repaired it and yesterday while doing a service on the front axle noticed that the oil flow from the final gear case on one side was a drip while it flowed freely out of the other side and bevel gear case too. Looking into the drain hole seems to be something is lower or a possible snap ring broke again causing the gear to drop ect blocking oil flow from drain hole, I can stick a small flat screw driver in the drain hole on one side but the other side is blocked. I am suspecting it to be reference #15 that fails and causes the gear to drop down and away from gear # 9 in the second pic.
I am going to pull the left side apart today to see if there is an issue before running it and trashing another gear set just to be safe, will maybe only cost me an o-ring versus the other option just to inspect for my own curiosity.
Does anyone have a link to a PDF service manual for setting the backlash on the gears since there are shims to do so so I can check if it is correct?
https://gpim-media.dibhids.net/ipc/ex45h-t565a.png
https://gpim-media.dibhids.net/ipc/ct445b-t575a.gif
