Page 6 of 6 FirstFirst ... 3456
Results 51 to 59 of 59
  1. #51
    Join Date
    Nov 2008
    Posts
    849
    Brampton, On\lot Powassan, ON Canada
    Kubota B4200\MF 135\Kubota B3200
    Default Re: Home made loader
    With a 12 hp 3 cyl diesel, my kubota B4200 is not much bigger then a Lawn tractor. This is my homemade loader with 36 in wide bucket. I have seven hard years on it now.
    Attached Thumbnails Attached Thumbnails Home made loader-tractor-001-jpg   Home made loader-dscf0007-jpg   Home made loader-dscf0010-jpg   Home made loader-dscf0014-jpg
    Unimogdave
  2. #52
    Member
    Join Date
    Mar 2010
    Posts
    28
    Hi, I present my loader to Yanmar YM2000
    This is my first front loader so please bear with us
    Drew a little too big motors, for a lengthened time head sadly.
    I used a cylinder to the bucket, but unfortunately the frame cross bar connecting the two branches began to bend, then wspawałem additional pipe and was about
    I was very pleased with him, I think I made it more robustly than sold to us in Poland Allegro.pl - aukcje internetowe, bezpieczne zakupy for this type of tractor
    Attached Thumbnails Attached Thumbnails Home made loader-010420101734-jpg   Home made loader-010420101735-jpg   Home made loader-010420101736-jpg   Home made loader-010420101737-jpg   Home made loader-010420101739-jpg
    Home made loader-010420101740-jpg   Home made loader-010420101744-jpg   Home made loader-270320101634-jpg   Home made loader-270320101638-jpg   Home made loader-270320101639-jpg
    Home made loader-270320101640-jpg   Home made loader-300320101728-jpg   Home made loader-balast-jpg   Home made loader-brak-poprzeczki-na-si-owniku   Home made loader-z-poprzeczka-dodatkowa-na-si
  3. #53
    New Member
    Join Date
    May 2010
    Posts
    2
    Thought I'd add mine to the mix. Built it in the fall and will be removing, grinding and painting in the spring. Most important part of a GT loader is the subframe. Spread the stress out over the tractor and provide a good connection to the driving axle.
    I've been moving mountains of snow and ice all winter and watching for issues with the tractor frame. All seems well with the exception of a few minor fluid leaks which will be addressed on the finishing.
    Wayne
    Attached Thumbnails Attached Thumbnails Home made loader-a71u5245-jpg   Home made loader-a71u5214-jpg   Home made loader-a71u5234-jpg
  4. #54
    Veteran Member Mechanos's Avatar
    Join Date
    Aug 2010
    Posts
    1,106
    Roosterville, MO
    JD 955/70A/7 TLB
    I searched and searched for a FEL for my JD 955. I couldn't find one that didn't seem to be gold-plated, so I resigned myself to having to build my own. I bought the plans for a CADLoader model 1006 from CADPlans. As my luck would have it, I found a FEL for my tractor two days after the CADLoader plans arrived in my mail box. Since I don't need them anymore, I'd be willing to make someone a deal on the set of plans.
  5. #55
    Member
    Join Date
    Dec 2009
    Posts
    43
    Built this one last winter and it came in useful with all the snow we are getting this winter. I'm working on a backhoe for it now.
    Attached Thumbnails Attached Thumbnails Home made loader-q-100_2995-jpg   Home made loader-q-100_3004-jpg   Home made loader-q-100_3007-jpg   Home made loader-q-100_3014-jpg   Home made loader-q-100_3023-jpg
    Home made loader-q-100_3027-jpg
  6. #56
    Platinum Member locknut's Avatar
    Join Date
    Jul 2006
    Posts
    837
    Greensburg Indiana
    I built mine last year from scratch,using ideas from this forum and others.Built a mockup out of 2x4's to get the angle on the arms right,then took it to the machine shop for the fabrication in steel.Haven't used it much till the last couple of days,moving crushed stone and regrading the alley out back.Works really slick so far and when I'm done with it I take it apart and hang it on the wall.I use electric actuators,2-18" for the arms,and two-12" on the bucket,controlled with solenoids and an arcade joystick.Lifts 400 lb easy enough.
    Wish I could find more things to do with it,it's a blast to use
    more pics
    Pictures by locknut-1 - Photobucket
  7. #57
    Join Date
    Nov 2009
    Posts
    79
    Gallatin, TN
    John Deere L110 and Mahindra 2816 4wd
    Quote Originally Posted by locknut View Post
    more pics
    Wow! That is some awesome fabrication!
  8. #58
    Gold Member Freakingstang's Avatar
    Join Date
    Nov 2011
    Posts
    389
    BOhio
    s370d
    I'm working on mine right now. The tractor is a 15 hp (pto) satoh with front wheel assist. I got a complete loader setup from an old economy tractor in a horse trade. I literally have about 100 bucks in the whole setup and I had 95% of the materials. I'm getting ready to make cylinder mounts now. The lift cylinders are only 3"x 12". I want to get a longer stroke for more lift, but I'm a little broke right now being a new home owner and right after Christmas. What size cylinders do you all recommend? I plan on using the current lift cylinders for the bucket curl when I can afford new longer lift cylinders.
    Here is a couple pics of mock up. Hopefully I cam move some snow and dirt soon.
    1999 Kubota G1900 HST B2750 Dozer blade
    Satoh S370D Beaver 4x4, 2 cyl Mitsu diesel, Custom FEL with Hay forks
    Woods RB60, KK 48" BB, Woods RM59 CCW, 48" Brinly disc, Farmhand Carryall, AB 1 btm plow, AB HH/trailer mover
    Angry Beaver Front End Loader build thread- Click Here
  9. #59
    Bronze Member CarterandCarter's Avatar
    Join Date
    Sep 2011
    Posts
    70
    Johnson City Tennessee
    kubota m9540, jd 2755,2355,4055,2940,2030,2030 with loader,McCormick c70, and a bobcat
    i must say as i was once a welder in the Bushhog facility in Jonesborough Tennessee that is a very good lookin outfit to be "homemade"
    Carter & Carter Machinery
    423-282-6969
    1233 Carroll Creek Road
    Johnson City Tennessee 37601
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
