charlz
Elite Member
My Kubota b7100 came with a b670 which had a 16" bucket. I have a fair amount of sprinkler line to put in and I decided to make a smaller bucket. I read some of the posts on here concerning dirt sticking in the smaller buckets but we don't have clay so I think it will be OK. Also, I could just rent a trencher but what fun is that?
I made templates from my original bucket, here are the materials, one bucket side already cut out:
I used the pieces for the 'ears' to help make the 90 angle that is at the back/bottom of the bucket.
Both sides now cut out, bottom bent, 'ears' made. I cut the sides with some Harbor Freight metal cut off wheels in my angle grinder. Worked pretty well and used about 1.5 of them
The original bucket and one pin had a wee bit of wear so I made a new pin. I thought about reworking the bucket to use collars on the ears and longer pins. I figured if this is what 30 years of use does the original design would probably work for me The holes in the original bucket were out of round about 1/4 inch on one side, some quick work with the welder and they were close to new.
Everything tacked together for a test fit on the tractor. It fit perfectly.
A lot of welding later and some wishing for a MIG the bucket is now ready for bending/welding of the bottom.
I still need to get the cutting edge material and some teeth. Without those two items I have about $42 in materials which includes the new pin. I think I have spent about 8 hours on it so far. Mostly checking and rechecking the pin hole locations before drilling
I'll post some pics after I finish it.
