RedDirt
Gold Member
- Joined
- Dec 4, 2007
- Messages
- 469
- Location
- Northern Idaho
- Tractor
- Kubota BX23, Wards 16HP HST Garden Tractor, (previous) D2 Logging Cat
My new/used BX23 came with a 5' back blade instead of the box blade I'd have preferred.
Though I don't expect the following proposal to work as good as a bone fide box blade, my use of it is very short lived. Once my drive is regraded it will rarely be used again.
For the bx 5' back blade:
Side plates: add 1/4" thick bolt-on side plates. 12" to 18" long, bottom of plates 1" up from blade cutting edge. Diagonal brace the side plates to the blade with strap or angle. Bolt-on braces at 45 degrees, set at middle of blade/plates. Maybe need two dia braces ea side; one a couple inches up from the bottom, the other at the top?
Rippers: Add a bolt-on, diagonally braced, cross tube perpendicular below the pulling arm and use 4 bone-fide toothed scarifier shanks slotted into the cross tube. I have some 4x4x 3/8" scrap for the cross tube. At the center, top, of the cross tube I'd weld a pair of 3x12x1/2 plates that would bolt or pin onto the 3x3x(?) existing pulling arm with 3/4" dia grade 5 bolts/pins. I think I'd run the back of the 3x3x1/2attachment plates flush at the back of the cross tube then forward from there the 12". Then I'd gusset the front face of the cross tube to the attachment plates to counteract the rotational load on the cross tube.
Existing driveway is thin layer of crushed gravel over packed clay, no rocks/boulders. Terrain is almost level. I intend to strip off and stockpile the existing gravel, regrade maximum of 8" (mostly 0" to 4") depth for correct drainage, crown and ditch, replace stripped gravel as a base and have a few more gravel loads hauled in for topping. Drive is about 600ft long.
Do you think the described rear blade attachments would do the job?
I know I won't be able to angle the blade with the rippers on unless I can set the cross bar ahead of the first angle adjustment. I have had reasonable success angle blading with the little back blade on my Wards tractor with side plates attached. Side plates on, angled and tilted, I've made decent shallow drain ditches. I expect more available tilt and depth with the TPH. The 4x4x3/8 cross tube may be a bit large but it's just sitting there, cheap.
Thanks for any feedback.
