Results 1 to 8 of 8
  1. #1
    Gold Member
    Join Date
    Dec 2006
    Posts
    254
    Western Ontario
    Bobcat 553, 773, S185, Nh LS 160
    Default Snow Plow Wings
    I was getting a bit tired of the time it takes to clear the parking area of my yard so I built a set of bolt on wings forward swept at 30 degrees to widen my 8' blade into a 10'
    I quite pleased with the performance as the plow now works as a pusher when the blade is straight and carries double the volume of snow. Also I can still angle blade with it.
    I would recommend this mod to anyone who cleans up moderate to light amounts of snow or finds themself carrying snow some distance
    The last pics is of the factory wings that make a blade into a pusher. They work ok and can be manually hinged in behind the blade for angle blading.
    Now what i'd like to try someday is a hinged version of these wings with cylinders so they could be swept forward or back. Anyone try that?
    Ken
    Attached Images Attached Images
    Dealer for Erskine ATI Wallenstein Baumalight Tracks Plus Dexter Axels & Wix.
    NH LS 160, Tn75da, Bobcat 773 S185 Longlist of Attachments
    www.skidsteerforum.com
    Location http://www.tagzania.com/item/21497
    NW Ontario
  2. #2
    Join Date
    Nov 2004
    Posts
    73
    Default Re: Snow Plow Wings
    You did an excellent job, but I'm wondering why you built your own if you already have a set of factory ones? Also, how did you manage to curve the steel for the face of the wings?
  3. #3
    Join Date
    May 2006
    Posts
    787
    hoyt, Ks
    century 2535
    maybe he started with a piece of 18" or 24" pipe to cut up - at least that's what a guy I know did to extend out his blade on the back of the tractor.
    Erik
    Mahindra 3510, box blade, pallet forks, 6' KK mower...
  4. #4
    Gold Member
    Join Date
    Dec 2006
    Posts
    254
    Western Ontario
    Quote Originally Posted by Northstar9126
    The factory set was on a plow I sold to a customer. I ordered in what he wanted but took a photo for future reference.
    I had the local steel supplier bend the plate in his break. I just gave him a piece of cardboard cut to the curve of the blade and had him match it. I want to make a knife edge to put on my press that pushes into a full width angle iron, set with the open side up. Then I can bend narrow pieces like that in the future
    Ken
    NW Ontario
  5. #5
    Gold Member 3238dpw's Avatar
    Join Date
    Nov 2006
    Posts
    348
    Central NJ
    Power Trac 425, C-121 Wheel Horse, 2 Exmark 60 inch zero turn mowers
    QUOTE]Now what i'd like to try someday is a hinged version of these wings with cylinders so they could be swept forward or back. Anyone try that?[/QUOTE]
    Here is someone who has done something simular
    BLIZZARD Snowplows
    Scott
  6. #6
    Gold Member
    Join Date
    May 2005
    Posts
    362
    West Kootenays, British Columbia
    Yanmar YM240D / Massey Ferguson 135 / New Holland TN75F / Pasquali 988 and 997 / Goldoni 20A, 226 and Maxter 70RS / Ferrari 76 and 85 / Holder A50 / Valpadana VMC 180 / Long 610 4WD
    I think you are thinking along this line? A friend of mine uses one for commercial snowplowing and will never go back.
    THE BOSS Snow Plows | Power-V Plows - Snow Removal Equipment, Plows, Snow Removal Blades
  7. #7
    New Member
    Join Date
    Jan 2011
    Posts
    1
    We built a set of extensions almost identical to yours. We used 24" pipe that is 1/2" thick and was exact curvature. The folding idea is good, but build them to swing up!! Other brands that swing forward and back tend to be too flat and not roll the snow as well!! Would have too much of gap with the Bobcat plows!
  8. #8
    Gold Member smiley's Avatar
    Join Date
    Dec 2003
    Posts
    447
    Upstate NY
    Quote Originally Posted by 3238dpw View Post
    Here is someone who has done something similar
    BLIZZARD Snowplows[/QUOTE]
    Although I front mounted the 8 ft blower on my big 4wd Massey, there has barley been enough snow this year to try it and have been thinking about adding wings to my 9 ft blade. I have a 125 foot push before I can start losing the snow without burying the neighbor and think that with the angled wings, I should be able to clear the entire upper portion in 2 or 3 passes.
    The Blizzard plows in scoop mode that 3238dpw linked above, look like they could be fabricated quite easily with just a single cylinder and pusher rod running across behind the blade, to actuate both sides at the same time with a single control lever. I think with some good stiff conveyor belt between the plow and ends it should easily contain the snow.
    If anyone has tried it, I'd sure like to see it. Maybe this will be another project this summer.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
