Results 1 to 10 of 10
  1. #1
    Veteran Member lhfarm's Avatar
    Join Date
    May 2002
    Posts
    1,125
    Central Indiana
    NH TC40DA
    Default Quick Hitch to Quick Attach Plate
    I started a project to attach an old snow plow frame to a QA plate for my TC40DA 16LA loader. Then I read this tread http://www.tractorbynet.com/forums/b...-qa-plate.html and really like the idea of a 3PH setup up front, making the QA a multi-purpose unit. Then I read this thread http://www.tractorbynet.com/forums/a...s-another.html and saw MrJimi's HF QH attached to a QA plate.
    As luck would have it, I was traveling to Indianapolis so I stopped by the HF store and purchased a QH for $70. So now I have the QA plate and the QH setting on the floor of the shop. I need to a) figure out how to weld and/or bolt the two together and b) figure out if I weld a tube across the bottom with tabs for the snow plow or to build a bar with tabs to fit the QH.
    Suggestions? I'm thinking I need to stop reading post and just do something!
    Barry
    Lawson Hill Farm
    NH TC40DA
    '64 IH Cub Lo-Boy
    '47 Willys Jeep CJ2a w/ PTO
    '49 Willys Jeep CJ3a w/ PTO & 3pt lift
    http://www.farmjeep.com/
  2. #2
    Join Date
    Oct 2004
    Posts
    1,158
    Lecompton, Kansas
    AgKing 2840 shuttle shift
    Default Re: Quick Hitch to Quick Attach Plate
    I don't have any suggestions but I plan to do the same thing, please take plenty of pictures so I can copy off of you. I think that makes for a sweet setup. Plus I can plow the drive before running over the snow.
    WmWms
  3. #3
    Join Date
    May 2006
    Posts
    726
    St.Marys County. Maryland/Tall Timbers Md.
    Farmtrac 300 dtc
    Take some pictures with them setup the way you want them to work.We'll go from there. Did that make any sense?.
  4. #4
    Join Date
    May 2002
    Posts
    1,125
    Central Indiana
    NH TC40DA
    Quote Originally Posted by bones1
    OK, here are some pictures. The QA plate fits perfectly. The QH is taller than the plate. I'm looking at welding a tube between the legs of the QH and will weld tabs for the snow plow to that. Or, I could build something to use the QH, welding tabs to the draw bar.
    The final shot is of the snow blade.
    Thanks
    Attached Images Attached Images
    Barry
    Lawson Hill Farm
    NH TC40DA
    '64 IH Cub Lo-Boy
  5. #5
    New Member
    Join Date
    Nov 2005
    Posts
    23
    olivebridge ny,thats near kingston ny
    FARMTRAC 360 TDC
    MAN IF YOU ONLY PAID 70.00 for the plate i got riped off i paid 200.00 for mine.
    good luck
    PAPY
  6. #6
    New Member
    Join Date
    Nov 2006
    Posts
    11
    Hi
    I would weld the square tube along the bottom of the QA plate and then weld your snowplow mounting tabs (strengthened with gussets) directly to the tube. Meyers plow instructions say that the CL of the mounting holes in the tabs should be 11 1/2" above the ground and I have found that this height is important as it controls the "dig" angle of the plow. There are incredible stresses on these tabs so the tube can help strengthen the QA plate and disperse stress along the length of the tube.
    The quick hitch can then be welded directly above the tube. I don't see the fact that it sticks up higher than the plate as a big problem as long as you have some good welds which can support the weight of impliments via the toplink or the weight of your plow via the chain top connection point.
    One last point, I see the quick hitch used to connect a scraper blade which has been turned 180 degrees to create a snowplow. I would assume that without trip springs as on a real snowplow, the fixed mount scraper blade might create some damaging twisting forces to the loader frame/quick hitch if either side of the blade digs into solid ground and does not trip. It might work for a low speed, light snow on pavement but I would be reluctant to use that setup on anything uneven. Greg
  7. #7
    Join Date
    May 2002
    Posts
    1,125
    Central Indiana
    NH TC40DA
    Quote Originally Posted by papy
    good luck
    PAPY
    I paid $70 for the quick hitch. I piad $85 for the plate, plus $40 shipping on e-bay. It appears to be well made.
    Barry
    Lawson Hill Farm
    NH TC40DA
    '64 IH Cub Lo-Boy
  8. #8
    Join Date
    May 2002
    Posts
    1,125
    Central Indiana
    NH TC40DA
    Quote Originally Posted by gpd9780
    Hi
    Thanks. That old plow (from an early Willys Jeep PU) is heavy. It does have good trip springs. I suspect it will be the heaviest thing I hang off the front, and for that reason, I will go with your suggestion of the tube for reinforcement.
    I've got a 3pt boom pole and a carry-all I plan to use up front. I'm fairly new at welding, so I'll just need to take my time.
    Barry
    Lawson Hill Farm
    NH TC40DA
    '64 IH Cub Lo-Boy
  9. #9
    Elite Member
    Rest in Peace
    MrJimi's Avatar
    Join Date
    Jan 2006
    Posts
    2,504
    NorthEast, Florida
    Case 1845 C Skid steer
    Barry, here are the pictures I spoke of
    I use one plate for more than one use
    Jim
    Click here for my current weather
    Case 1845C with dirt bucket, forks, 3 point quick hitch on the front, 30'. boom, 6 & 1/2 foot disc harrow, 5 foot Howse RC, root and tree bucket and Grouser tracks and a Ford F-550 pick up,7.3 Turbo with Auto and a Crosley 25' X 8'.6" X 14 K D/O trailer.
    PDF files don't like me !!
    Making a F-550 Pick Up thread
    My Gallery
    My other Gallery
    Revielle video here
    Dear Eliot
  10. #10
    Platinum Member rtdiggr's Avatar
    Join Date
    Sep 2007
    Posts
    574
    Ont. Canada
    Massey Ferguson 1433v
    Quote Originally Posted by lhfarm
    That seem like a pretty good deal to me.
    The job looks good so far.
    Shane
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
