Results 1 to 4 of 4
  1. #1
    Join Date
    Dec 2007
    Posts
    81
    Default 3 Point Hitch Fork Attachment
    Here is my recent project. I am gonna make a fork lift attachment for my 3 point hitch so I can pick stuff up and use it as sort of a weight box also. Here is what I have so far. I have the edges all tack welded. All I have to do is weld it thoroughly. And I have to find metal for the forks. Anyone have any ideas. I am gonna try and find square tubing like 2x2x1/4 and use that but if I can anyone have any ideas?
  2. #2
    Super Member JB4310's Avatar
    Join Date
    Feb 2005
    Posts
    5,645
    Central CT
    J.D. 4310 E-hydro
    Default Re: 3 Point Hitch Fork Attachment
    Maybe just more of that same angle iron you used to make the frame with, those carry alls that you buy are built like that. just set that frame on the two angles so to wrap the bottom corner of the frame, then you would have the most surface area to weld, the only problem with that is the sharp side of the angle would be up instead of the flat part.
    Maybe some real forks from a scrap yard.
    Good luck,
    JD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 48", 61"HD & 73" high volume bucket.
    FORD 1700; 2 WD, 2600 hrs.
    JD 320; Hydra lift, 48" deck and 48" snow blade.
    2007 Dodge Ram 3500, Cummins 6.7L, Aisin 6 speed, 9ft utility body.
  3. #3
    Gold Member
    Join Date
    Dec 2007
    Posts
    437
    I built one I use for a carry all. It is made of 2x2x1/4 wall tube. mounted on 2x4x1/4. It will lift up the front of a car without issues. I don't know how much you can put on it but it is a good amount.
    Jeff
  4. #4
    New Member
    Join Date
    Oct 2007
    Posts
    8
    Paris, TX
    Kubota 3830 HST
    you can use 4 or 5 inch c channel, then weld flat metal on the top. Be sure to cut the sides near the end of the c-ch. at an angle so you can have a point at the end.
    05 3830 HST Grand L w/QA 723 Loader
    62 Massey 1100
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
