POST YOUR PICTURES OF FORKS?
   / POST YOUR PICTURES OF FORKS? #1
JRP
South Texas
Kubota M6800
I have a need for a forklift fork arrangement and others probably also do. I'd like to start a thread that has all pictures of loader or forklift fork arrabgements. It would provide a lot of good construction ideas for myself and others.
I bought a used set of forks yesterday; $126 for a pair, 4" wide by 4' long. Forks are easy to find. Because I don't have a loader yet I'll make a set that will fit my future loader, then add pins for 3pt. When finished it will be useable for either.
If you have forks, take a picture and post it. Let's try to have a picture with every post.
This "Build it yourself" is a great forum. Thanks Muhammad.
JRPoux
Another set from a Kubota
   / POST YOUR PICTURES OF FORKS? #3
Here is one of my sets:
   / POST YOUR PICTURES OF FORKS? #4
Here is my second (refined set):
Here is a previous post I wrote that may be helpful with the thought of this post, basically what I have figured out making my 2 sets:
I don't have Deere's forks, but I made my own. They can lift quite a bit. What I have learned: The first set was built out of 42"x4" forks from a fork lift (very heavy, my setup weighed 300#) was able to lift 600 to 700 with only a back blade for counter weight.
42" in front of the loader is a LONG way. Lesson learned! Need smaller forks and less weight.
I found a set of forks in a scrap yard off a hand truck fork lift, like the ones shown in this link:
http://www.wescomfg.com/lift-prod.html
$10 and 5 minutes later, they went home with me. They are 27" long, 3" wide and much, much lighter. I am really happy with this set!!
This is really the way to go. I think these forks are the perfect size for the 4100/410. They are big enough for most tasks. The forks themselves had a 1000# capacity on the hand truck, so strength wise, they are well matched to the capacity of the loader. The fork attachment that deere sells, IIRC, weighs near 500#, and the carriage itself is rated for, I think, 3000#. So you buying a lot of weight for capacity you cannot use with a 4100, I won't even mention the price. The only down side, is that I have not made a backstop/carriage as nice as the deere ones.
I can provide better pictures and details if anyone wants to undertake this project. Its really a simple build if you have the base skills. I welded it, but it could be done with bolting too. Feel free to email me for details!
Craig
   / POST YOUR PICTURES OF FORKS? #5
Here's the link to a picture of mine, sort of forks, more like material handling tines (4 of them) and a hydraulic grapple thumb. Most of you have already seen this link, but I thought I'd put it in here for someone reading to get ideas all in one place.
<A target="_blank" HREF=http://www.tractorbynet.com/forumfiles/5-121045-MAR_0021.jpg>http://www.tractorbynet.com/forumfiles/5-121045-MAR_0021.jpg</A>
Here's a link to the entire thread showing the Base frame, the grapple, the gin pole, and the personnel cage options:
<A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=implement&Number=121040&page=0&view=collapsed&sb=5&o=&fpart=all>http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=implement&Number=121040&page=0&view=collapsed&sb=5&o=&fpart=all</A>
   / POST YOUR PICTURES OF FORKS? #6
   / POST YOUR PICTURES OF FORKS? #7
Do clamp-on bucket forks count?
Harv, where'd you get those clamp-on forks? And, what weight are they rated for?
   / POST YOUR PICTURES OF FORKS? #8
Those are just what I'm looking for/w3tcompact/icons/smile.gif
   / POST YOUR PICTURES OF FORKS? #9
Roy -
Mine are the smallest (32") from Gearmore and I paid $350 for them new. They weigh 90 lbs apiece and have a 1,000 lb capacity.
Gearmore offers the following clamp-on forks:
2" x 3" x 32", weighs 90 lbs, lifts 1,000 lbs.
2" x 3" x 36", weighs 120 lbs, lifts 2,000 lbs.
2" x 4" x 42", weighs 190 lbs, lifts 3,000 lbs.
2" x 4" x 42", weighs 220 lbs, lifts 4,000 lbs.
   / POST YOUR PICTURES OF FORKS? #10
Let's see if this copy paste works.
<A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=implement&Number=80931&Search=true&Forum=All_Forums&Words=gotrocks&Match=Username&Searchpage=1&Limit=25&Old=allposts&Main=80931>http://www.tractorbynet.com/cgi-bin/compact/show...80931</A>
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A53472)
2021 John Deere...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
WESSEX CRX 240 LOT NUMBER 169 (A53084)
WESSEX CRX 240 LOT...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
2007 National RV Dolphin 35FT Class A Motorhome (A51694)
2007 National RV...
