HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 03-17-2008, 02:37 AM   #1 (permalink)
dfkrug's Avatar
Default Diesel fueling system for CUT owners
This is my second design of a fueling station for my compact tractors.
Some TBN members may recall my first approach, a modified jerry can
that used air pressure to dispense fuel.
http://www.tractorbynet.com/forums/b...sy-easier.html
It worked, but a jerry can is not a pressure vessel and the fill port did
not seal all that well. It only held about 4.5 gallons, too.
My new design easily holds 12 gallons of fuel, leaving plenty of space
for compressed air. It will primarily be useful to those of us who don't
use lots of fuel. I use between 5 and 10 gallons per month, max. I hate
hoisting 5 gallons of any liquid to shoulder height to fill my tractors. I don't
like the stinky spills either. This tank is very easy to fill, either with
5-gal portable containers, or hoisted into the back of a pickup. I chose
pneumatic pressure to power my fueling system because it is very convenient
and fast. I fuel my tractors in or near my workshop where I store them.
That is where I keep my compressor and air lines, but this new system
can also be pressurized there and taken out into the field.
My new design uses a cut down 20-gallon propane tank that I acquired for
free. This tank is a little over 4-ft tall and 13 inches in diameter.
__________________
See my TBN projects at:
http://mysite.verizon.net/resyfcgt/
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Diesel fuel dispenser
Bucket dentistry
custom hydraulic b/h thumb
adapting a 4-in-1 bkt to my Kioti
JD 4300 rebuild (new!)
dfkrug is offline   Reply With Quote
Old 03-17-2008, 02:55 AM   #2 (permalink)
dfkrug's Avatar
Default Re: Diesel fueling system for CUT owners
Cutting up old propane cylinder.
I used a plasma cutter, with a plastic guide to get as square a cut
as possible. I used a scrap of 3/16" flexible plastic with a straight
edge and bound it to the tank with a strap. Lining up the straight
edge assures a square cut. (This is a great trick for marking or cutting
any cylindrical material.) Photo D shows how tight the two cuts came
out.
Rolling the tank along wooden 2x4s allowed me to cut in one continuous
pass. This tank is nearly 3/16" thick! Two cuts were done in about
10 minutes.
After cutting, I had to clean out the tank.....that was the hardest part
of the whole project. I used an angle grinder with wire wheel. RUSTY!
__________________
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
Old 03-17-2008, 03:01 AM   #3 (permalink)
dfkrug's Avatar
The tank bottom was interesting. It had two drain plugs, both of
brass with lead centers. The strange metalurgy must be to arrest any
electrolysis inside the tank. This tank dates back to 1929, according to
the earliest pressure test stamp on top.
This photo shows the bottom, along with some gussets I made from some
scrap tubing. These will support 3 casters.
__________________
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
Old 03-17-2008, 03:25 AM   #4 (permalink)
dfkrug's Avatar
Now the top.
First I free-hand cut the existing top off. First photo shows the filler
plate and a chunk of 1.5 inch pipe and pipe cap. The nipple and cap will
form the filler hole, and the hook will be the handle. Voila, photo G.
Next I needed a 1.5" hole and a couple smaller ones for a schrader valve
and a pressure guage. Photo H shows how I cut the big one, using my old
friend, the plasma cutter. First I drill a small pilot hole, then I hold my
aluminum template where I want the hole. 15 seconds later, you see the
hole in photo I. If I do not drill a pilot hole, the plasma cutter splashes
back for a fractional second until it penetrates the steel. That's not a big
problem if I am wearing a mask, but it can lead to damaging my template.
The big hole is for the fitting that will support the dipper tube and the hose
fitting for the nozzle.
Photo J...all done with the top.
__________________
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
Old 03-17-2008, 03:30 AM   #5 (permalink)
dfkrug's Avatar
Next I drilled and tapped two holes for a sight tube level guage.
I also welded steel guards on each side of the tube, for protection.
Clear PVC should hold up to the diesel fuel, as long as I don't allow
UV to age it.
__________________
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
Old 03-17-2008, 03:43 AM   #6 (permalink)
dfkrug's Avatar
And here is the finished product.
I stole the hose and commercial nozzle from my previous filler system.
The hook filler cap allows me to get a good seal just using my hand to
tighten, as well as a way to lift the whole tank into my pickup.
The second hardest part of the project was passing the leak test. Since
I do most of my welding outside to avoid fumes, it is easy to get a very
slight invisible "micro-porosity" in parts of the weld. 50 psi of air finds all
of those. Small leaks are not crucial as all welds are above the fuel line,
but I eliminated all leaks anyway. I used a MIG welder (Hobart Ironman 210).
That is why some of my welds are as pretty as they could be (big).
Photo M shows the nozzle holder and drip catcher. This nozzle is amazingly
leak-free. Photo N shows my sight guage and guard. The fuel level will be
even more visible when I switch to red diesel.
__________________
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
Old 03-17-2008, 03:48 AM   #7 (permalink)
dfkrug's Avatar
Fill R up!
This system works even better than I expected. I put about 10 gal
into it the other day. I pressurized to to about 10psi, which took about
10 sec. Then I added 5 gal of fuel to my tractor, which took about
15 sec. 3 seconds/gal. Sure beats a hand pump!
__________________
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
Old 03-17-2008, 09:20 AM   #8 (permalink)
Bedlam's Avatar
Wow Amazing, I sure love it when a plan comes together. And on the cheap too.
Bedlam is offline   Reply With Quote
Old 03-17-2008, 02:52 PM   #9 (permalink)
Member
Now that's just way too slick. Think
I'll have to make one myself. That's if
I can afford the diesel, $4.399 this morning
here in beautiful Eastern Connecticut.
Kowabunga!
Bill
__________________
Bill Hoffman
Cadet 1811 w/MMM & blower; Yanmar 155D w/ South Bend Loader, Woods 750 backhoe, Woods M4 Hog, er, piglet; Kubota B7800 w/loader, MMM, weight box. Plus a bunch of other stuff
Bill Hoffman is online now   Reply With Quote
Old 03-17-2008, 05:57 PM   #10 (permalink)
Elite Member
wushaw's Avatar
That is a job well done
It works like a champ to boot.
wushaw is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.33868 seconds with 9 queries
