Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 29
  1. #11
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Default Re: Bucket Teeth/Home Made?
    Quote Originally Posted by YukonKing
    Plus it will trully tell me if I should have bought her "implants' or just "dentures".
    YukonKing
    Well, I think your implants will be a bucket of grief instead of bucket teeth. If the teeth stick out very far in front of the lip, they will put tremendous twisting force on your bucket's cutting edge and maybe even twist and distort the bucket's sheet metal. You need a thick bar to mount the teeth onto and a groove over the lip to keep the teeth from peeling upwards when you hit a rock. It won't be long until you are snaggle-toothed. you might prevent this by drilling and bolting the teeth to the bucket, but it all seems so futile when $300, shipping, and a little patience could get you a very nice tooth-bar instead of a homemade headache.
    I know your tractor is only 25 hp, but I don't think that will matter. I just can't be positive about your chances. Color me skeptical.
    Jim
  2. #12
    Member
    Join Date
    Sep 2005
    Posts
    25
    Vaughn, Wa
    Mitsubishi MT1801D
    You can do a search for "Toothbars" and get some very good ideas from this forum. I actually just finished fabbing up a set of them for my little Mitsu Gray. Since I live near cities I can get ready made teeth, tho I seriously considered fabbing up my own, I ended up with the ready-made dentures. I considered permanent, but decided I'd like to be able to use the bucket edge for smoothing & I have several other self-fabbed implements which rely on that smooth bucket edge. Let's see if I can figure out how to attach my photos.
    Attached Images Attached Images
  3. #13
    Member
    Join Date
    Sep 2005
    Posts
    25
    Vaughn, Wa
    Mitsubishi MT1801D
    If I were you, living where you do..I would not be a BIT shy about fabbing up my own teeth. My suggestion would be to do up a tooth that you can weld to a bar to be bolted onto the bucket & removed when needed. Just make sure to shape the teeth so they hook under the front cutting edge of the bucket so it can bear the stress.... & Bob's your uncle!
    Mike
  4. #14
    Elite Member
    Join Date
    Oct 2003
    Posts
    3,623
    the Steernbos (Holland)
    Zetor 3011, Zetor 5718
    If you need some wear resistant steel to weld under those rods, use pieces of old leaf springs: its allmost as good as original teeth !!
    Just dont waste your band saw on them, but torch 'em or use a grinder.
  5. #15
    Join Date
    May 2004
    Posts
    167
    Willis, Texas
    FarmTrac 300DTC
    Mike,
    May I ask where you got your teeth from?
    Chris
    Quote Originally Posted by miketheDrummer
    Chris
    Farm Trac 300DTC w/5140 FEL and stuff
  6. #16
    Veteran Member varmint's Avatar
    Join Date
    Mar 2003
    Posts
    2,399
    Northern Maryland
    Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
    I posted this some years back, but it's worked well for me, with my 19 hp kubota B8200... I bought forged combine teeth and some bar, and the welded up, easy to attach and remove tooth bar has held up to whatever abuse I have subjected it to. I could take some better fotos if anyone out there was interested.
  7. #17
    Join Date
    Jun 2006
    Posts
    175
    YukonKing,
    A few years ago I needed to get a toothbar for my tractor but did not want to spend the $300.00 for one either. While working in my shop one day I noticed a stack of leaf springs and the idea hit me. Springs are made of some tough metal. I disassembled the springs and cut them apart using a metal blade in a skill saw. I used 3/4 inch bar stock and three pieces of leaf spring to form a wedge shaped tooth. I cut holes in the leafs to bolt to my bucket and welded together. After making each tooth the next was a little different design so they are not all identical.
    When I put these teeth to the test the spring material kept snapping near the welds when backdragging. I would reweld but the breaking would occur again. The problem was due to the spring metal becoming brittle near the welds. The springs (teeth) needed to be tempered. I wanted to heat the metal to 500 to 600 degrees F and hold there for a while. I thought of cooking them in the kitchen oven with it in the self cleaning mode. Instead, I used the gas grill with it turned on high and cooked the teeth for about an hour then let cool slowly. Since then I have not had any breakage.
    If I were going to buy old springs from a salvage yard, I would buy ones from a large truck like a dump truck. Mine are smaller since them came off of a 1/2 ton truck which I had taken the axle from. You might find used springs at a truck spring shop. I hope this helps.
  8. #18
    Join Date
    Aug 2007
    Posts
    84
    Whitehorse Yukon Canada
    JM254 4x4
    Ok,
    So I'm resurecting this old thread. Yesterday I started building my tooth bar.
    So far everything is tacked together. I'm using a tinny winny welder to tack with so the welds look like crap, The bar stock was exchanged for 1" solid square stock as in the drawing. I will get some pictures up later today.
    So far I looks good.
    YukonKing
    Attached Thumbnails Attached Thumbnails Bucket Teeth/Home Made?-tooth2-jpg
    2007 JM254 with FEL and BH
  9. #19
    Gold Member POC's Avatar
    Join Date
    Mar 2008
    Posts
    310
    Southern Indiana
    Mahindra 3215 4x4
    I like this. Using the leaf springs and tempering them is a great idea.
    Yukon, you might want to think about putting a flat bar inside to add some strength, or even underneath the front lip.
    I love this website. :-)
    Dancing Goat Farm
    Southern Indiana
    Mahindra 3215, 111 FEL, 3710 BH
    JD X300 Lawnmower (I refuse to call it a "tractor")
    Ford 600/800 mix-n-match
    IHC A-160
  10. #20
    Join Date
    Aug 2007
    Posts
    84
    JM254 4x4
    ok,
    so made some forks too. total cost 100$.
    Attached Thumbnails Attached Thumbnails Bucket Teeth/Home Made?-tractor-017-medium-jpg   Bucket Teeth/Home Made?-tractor-018-medium-jpg   Bucket Teeth/Home Made?-tractor-019-medium-jpg   Bucket Teeth/Home Made?-tractor-021-medium-jpg   Bucket Teeth/Home Made?-tractor-022-medium-jpg
    Bucket Teeth/Home Made?-tractor-023-medium-jpg   Bucket Teeth/Home Made?-tractor-024-medium-jpg   Bucket Teeth/Home Made?-tractor-025-medium-jpg
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
