HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 04-08-2008, 12:10 PM   #1 (permalink)
New Member
Default Redneck dump truck
Here is how I haul dirt with my BX2350. It works quite well. I can do it all without leaving the seat of the tractor.
To dump it, I just raise it into the air as far as it will go, lower it slightly, roll it forward, lift it all the way again, and it usually all slides off by then.
I am going to add 2x10s on each side to haul a little more dirt.
DrewWalker is offline   Reply With Quote
Old 04-08-2008, 12:22 PM   #2 (permalink)
yekrut's Avatar
Default Re: Redneck dump truck
That's a pretty slick little set up. Where did you get the trailer bed? Did you make the modifications or is that how it came? I guess I'm wondering what was it before?
yekrut is offline   Reply With Quote
Old 04-08-2008, 02:48 PM   #3 (permalink)
New Member
The "trailer" was made from an old 1-ton flatbed dually. The frame rails were cut and welded together in a "V" to make the tounge.
Old 04-13-2008, 11:15 AM   #4 (permalink)
JB4310's Avatar
Drew,
I like yours, I have done somthing similar with an S-10, kinda light duty, I made one out of a dually IH long ago also. yours has a better dump angle due to the bed being over the wheels, with mine I had to take the tail gate off and lift it up on the bumper to get it to dump.
I now have a 5 ton dump trailer, but my "red neck dumper" worked when I needed it to.
JB,
redneck-dump-truck-p4113900.jpg  redneck-dump-truck-p4113902.jpg  redneck-dump-truck-p4113896.jpg  redneck-dump-truck-p4113898.jpg
__________________
JD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 61"HD & 73" high volume bucket.
FORD 1700; 2 WD, 2600 hrs.
JD 320; Hydra lift, 48" deck and 48" snow blade.
JB4310 is offline   Reply With Quote
Old 04-13-2008, 03:02 PM   #5 (permalink)
nice...
I am about to do something similiar with a 5x8 utility trailer..
It has a 3500 lb axle and is fairly heavy about 600 lbs empty...
Any ideas on weight limits and lift problems?
I have a L3400 with LA463 loader.
Thanks,
Jim
RadarTech is offline   Reply With Quote
Old 04-13-2008, 04:30 PM   #6 (permalink)
ChuckinNH's Avatar
Hmm, In Vietnam, we used the wreckers to lift the whole duce and half truck, and that worked pretty well, except all the oil ran up the steering column and messed up the horn.
__________________
B2620,Loaded R-4's , Wallenstein BX42 chipper, Bush Hog SQ148 RC, 4' x 8' chain harrow, and more to come...
ChuckinNH is offline   Reply With Quote
Old 04-13-2008, 10:57 PM   #7 (permalink)
akpilot's Avatar
Quote:
Originally Posted by JB4310
Drew,
JB,
Thanks for the idea I wanted to figure a way to haul screened material from my screening plant to the area that I plan on landscaping, without making hundred trips with the tractor. I have an old ford courier that I could do the same thing to!
akpilot is offline   Reply With Quote
Old 04-14-2008, 01:06 AM   #8 (permalink)
xlr82v2's Avatar
Werks purrty guud, don't it?
http://www.tractorbynet.com/forums/p...ump-truck.html
__________________
_____________________
Brian
2007 Mahindra 3525
1952 Ford 8N
xlr82v2 is offline   Reply With Quote
Old 04-15-2008, 05:57 PM   #9 (permalink)
have_blue's Avatar
Quote:
Nice inexpensive dump bed, but I bet the dumping mechanism cost $3-$4K.
I thought about 1 similar to that, but with a tilting bed. The dirt would ride slightly behind the pivot point, so tripping a release would dump instantly by gravity. The bed would then bang back down by its own weight and latch itself.
__________________
Bob
From the heart of Cajun Country
have_blue is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
