HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 04-12-2008, 12:07 PM   #1 (permalink)
Default Nutty Washers
Got some 7/8 washers and 3/8 nuts drilled out a tad to accept pins and went to welding. What ya'll think?
nutty-washers-washer.jpg  nutty-washers-washer1.jpg  nutty-washers-washer3.jpg
__________________
Kubota L3400, FEL, BH75 back hoe, Land Pride 58"tiller, Melonzi 48" Root Grapple, Box Blade, Forks, PHD,
digicamnut is offline   Reply With Quote
Old 04-12-2008, 01:38 PM   #2 (permalink)
Default Re: Nutty Washers
Cool idea, That was a consideration with the hitches, how to make or buy the washers.I never thought of that way I figured if I were stubborn and cheap Id have to bend the washers and then drill a hole in them for the pin to go through. Your way is much simpler.
thanks for posting it.
Al
__________________
silenced1206
Bedlam is offline   Reply With Quote
Old 04-12-2008, 08:34 PM   #3 (permalink)
shvl73's Avatar
I like it! Thanks for the pics.
shvl73 is offline   Reply With Quote
Old 04-12-2008, 09:35 PM   #4 (permalink)
OK,
I got to ask. What is the purpose of the nut and washer? I see how it works, but don't understand the need. Please enlighten me. Thanks,
Mike
BayouMan is offline   Reply With Quote
Old 04-12-2008, 09:58 PM   #5 (permalink)
Quote:
Originally Posted by BayouMan
OK,
Mike
The washers stay on the implements. Quick hitch not against linch pin. Really better when hookin up to implement. Hope this helps. They are really easy to make. Even for a cajun like me.
craig
__________________
Old 04-12-2008, 11:55 PM   #6 (permalink)
EZ-HITCH's Avatar
Pretty good idea!! We have had a few customers ask for the bent washers with a hole in them, and we have been happy to provide them. However, I like the "Nutty Washers" better. I think they would tend to stay in place better then the bent washer which have a tendancy to move around a little.
EZ-HITCH is offline   Reply With Quote
Old 04-14-2008, 06:42 AM   #7 (permalink)
johnk's Avatar
Quote:
After seeing this post I had to take a trip to TSC and buy some Nuts and Washers. Welded them up and they work great. Thanks for the invention.....
johnk is offline   Reply With Quote
Old 04-14-2008, 10:13 AM   #8 (permalink)
OK,
Mike
The Quick type hitches engage an implement pin from below with a U shaped socket. The linch pins do not have to be removed, but are rather ineffective with the u shape unless protected by a washer. This idea captures the washer against the L pin so it doesnt slip inward and get in the way when hooking up.
larry
SPYDERLK is online now   Reply With Quote
Old 04-14-2008, 10:28 AM   #9 (permalink)
Quote:
larry
Thanks, Much better said than my explanation.
Larry, I'll do the dishes while you work on the computer... . I never was good with words.
__________________
Old 04-15-2008, 08:54 AM   #10 (permalink)
New Member
I,m new here but hanging on for quite a while.At the risk of starting a fire storm, I would like to relate my experience with this type hitch. while cutting hay with a drum mower on hilly terrain the lynch pin and washer were pushed off at the quick hitch.I destroyed the the drive shaft going to the mower and bent the PTO shaft on my Massey 180. An expensive lesson.There must be a lot of force at the lynch pin maybe because there is no socket ball to equalize the pressure.Also the bent washer set up doesn't always allow the lynch pin to close completely. I ground mine down to leave just a tab,much like the nut in this post.It popped again while I was pulling a chain harrow with NH TC 35. Sharp turns. Lesson .....wire the hitch pins closed so they can't come off.Now I undestand why the Speeco quick hitch has the special Pins that fit over the implements hitch pins .It's impossible to pull them through the hitch. Good engineering. Sorry this is so long ,but it may save someone some grief. WIRE THOSE LYNCH PINS CLOSED,
kidr is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
