HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 04-16-2008, 07:42 PM   #1 (permalink)
Member
Default Side Link
Has anyone here ever built a hydraulic side link for their 3-point adjustment? If so, how did you weld the ends on a cylinder? Is a check valve neccessary to keep it from drifting? I realize I can purchase one from Carter & Carter for about $250, which may be the way to go in the end. The cheapskate in me says try it though. Whats your opinion? Thanks in advance.
petegoud is offline   Reply With Quote
Old 04-16-2008, 08:52 PM   #2 (permalink)
MtnViewRanch's Avatar
Default Re: Side Link
Mine is home made. Bought the hydraulic and cut off the ends. cut the ends off of the factory side link. welded the top end onto the cylinder. Bored a hole through the clevis end, turned the rod down to size at the end so that clevis end was a press fit, and welded.
Probably don't really need to do all that stuff at the clevis end, could have just welded it.
Oh, and I would not want a check valve on mine, I sometimes put it in float mode and drag the ground smooth letting the blade move with the terrain of the ground.
__________________
Brian
MtnViewRanch is offline   Reply With Quote
Old 04-16-2008, 11:41 PM   #3 (permalink)
Member
Thanks Brian, I never thought about leaving it in float mode.
Doug
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
