#1 (permalink) |
I've got it on my mind to make a 25 to 40 gallon 12v boom sprayer, has anyone ever converted a wand type spot sprayer into a boom type sprayer or would the pump be too small? I have a carry all I can mount the tank on and wiring it up isn't a problem, but I don't know about the pumps for them, any ideas?
#3 (permalink) |
Gold Member
I did that exact thing I used 4 standard nozzles on about a 7 foot boom. It is on a 25 gallon wand sprayer setup with a 2gpm pump. It used to maintain about 20 psi now it's lower, the cheap guage quit on me so I don't know exactly how low but it still gets good coverage. I think I would use a couple of those boomless sprayer nozzles instead of building a long boom if i did it again. I was worried about drift and wanted to get the boom as low as possible to the ground and still cover the area. I took many trips up and down the driveway experimenting with different nozzles and boom heights.
I want to upgrade the pump to a 3gpm pump sometime but it works rfor now. Here are somer pictures of my setup. ![]() ![]() ![]()
__________________
Bernie |
#4 (permalink) |
I'm working on that now. My brother came up with some 1" square tubing and angle iron. I bought everything else from TSC. They have special clips made for 1" tubing that the nozzles will fit into. Bought a small pack of 1/4" hose, a ball valve and some hose clamps. So far have spent about $55.00 but haven't put any of it on my 25 gallon sprayer. Will use three nozzles.
#5 (permalink) |
Most of the 25 gallon spot sprayers have a pump large enough to handle a small boom. Most of the pumps are rated in GPM at a given pressure. Most nozzels are also rated in GPM at a particular PSI so you know how fast to spray for a given coverage. If you can get pump and nozzel specs, you can put together the right combination. I think mine is 2.1 GPM at 40 PSI. I started out with a 80" coverage 2 nozzel boom and had no problem maintaining 40 PSI at the boom and was still dumping liquid back to the tank. I calculated that I could add another nozzel for 120" coverage, and still maintain 40 PSI with no excess being returned to the tank. This works great for me.
I was going to build my own originally, but after looking up all the parts, I found it pretty hard to beat the cost for a 25 gallon spot sprayer and a basic 2 nozzel boom kit($47?) from Agri-supply. The original manufacturer was Fimco, and I was able to order a matching additional nozzel and "T" from them directly when I upgraded to a three nozzel boom. I built a tow behind cart for it out of 1" box tube and two wheelbarrow wheels.
__________________
Ron |
#6 (permalink) |
I built this sprayer that I use on the back of my garden tractor. I can drop this tank on a quick attach bracket and be ready to go in 2 minutes. I like it on the back of the tractor because it is easer to use than a trailer. I can spray 60" but my change it to cover more area. I can still use my wand or switch over to the boom. I bought the standard spot spray tank (26 gal) from Northern. The first valve shuts off the boom to use the wand. The "Y" sets the preassure to the nozzles.
#8 (permalink) | |
New Member
Quote:
Looks like you have some wild violets in the yard. Have you had any luck trying to kill those things? |
#9 (permalink) | |
Gold Member
Quote:
2-4-D based stuff knocks them back a little but they come back The county extension agent said try douling up on the concentration.
__________________
Bernie |
#10 (permalink) |
county extension agent better get his stuff together. The label on that herbicide, is law. Him reccommending you double the strength is way beyond his relm.
I would get hold of the herbicide manufacturer and see what they sat to do. |
| Thread Tools | Search this Thread |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
