HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
LinkBack Thread Tools Display Modes
Old 05-21-2008, 07:42 AM   #21 (permalink)
Wayne County Hose's Avatar
Default Re: Hey soil screening builders
Boy, too bad we all couldn't get together and have a screening plant build party! A barbecue, some welders and a pile of steel, it don't get much better!
__________________
Knowing is not enough, you must apply.
Willing is not enough, you must do.
Bruce Lee
Wayne County Hose is offline   Reply With Quote
Old 05-21-2008, 07:47 AM   #22 (permalink)
Elite Member
MrJimi's Avatar
Quote:
All hydraulically operated
__________________
Click here for my current weather
Case 1845C with dirt bucket, forks, 3 point quick hitch on the front, 30'. boom, 6 & 1/2 foot disc harrow, 5 foot Howse RC, root and tree bucket and Grouser tracks and a Ford F-550 pick up,7.3 Turbo with Auto and a Crosley 25' X 8'.6" X 14 K D/O trailer.
PDF files don't like me !!
Making a F-550 Pick Up thread
My Gallery
My other Gallery
Revielle video here
Dear Eliot
MrJimi is offline   Reply With Quote
Old 05-21-2008, 09:16 AM   #23 (permalink)
here's my answer to the hydraulicaly operated towed screener
chickenman is offline   Reply With Quote
Old 05-21-2008, 11:16 AM   #24 (permalink)
SkunkWerX's Avatar
Quote:
ChickenMan, your machine is approaching "legendary" status. I have stared at those photos quite a bit.
Question for you, Are you shaking the grate mechanically, if so, how?
Or is it just the conveyor with mostly gravity doing the sifting work?
__________________
Kubota BX2350, 60" MMM, FEL w/Grapple, bucket forks, 4' KK Tiller, 5' RGB, 5' Rake, Gauge wheels, 4' Cutter, Quick Hitch, 3Pt. TowBar, 3Pt. 35 Gal. Sprayer.
SkunkWerX is offline   Reply With Quote
Old 05-21-2008, 11:53 AM   #25 (permalink)
after sorting out the bugs im pleased at how well it cleans
it picks up all but pea sized stones 1/4 to 3/8 inches
Old 05-21-2008, 01:57 PM   #26 (permalink)
StrangeRanger's Avatar
Send a message via Yahoo to StrangeRanger
Quote:
Originally Posted by akpilot
I think it is possible!! I think you will want to run the the pulley in parallel with the direction on slope to reduce side-side motion, which would be hard on your frame. I don't think a vertical shaft is that much of a problem, run a long enough belt to put a 90 degree twist to put the pulley shaft on horizonal plane. Good Luck!!
I was thinking that a long belt would allow me to twist it to 90*. Just needed to hear someone say it's ok
I'm not too worried about side-side motion. The design in my head (haven't even made it to paper yet) is basically re-enforced screen box/frame that will be suspended by some big honkin heavy duty springs from the 4 corners. The frame will of course be angled. The motor will be mounted to a post on a stand w/ a long belt running to ??? mounted on the screen frame. The ??? will basically just shake the piss out of the screen box in all directions I'm guessing.
I've got grass/weed clumps etc that I've got to deal w/ so I'm sure it will take some hand work too.
My only bummer so far is I located a fee mower engine to use, but it's the type w/ just the safety cable attached to it, no throttle control. Gotta figure out how to rig up a throttle b/c I don't want that thing running full tilt. Should be interesting
j
__________________
j
L3400 HST, LA 463 FEL, 6' Woods blade, 65" Woods box blade, 60" Meteor blower, CCM top & side links, 2 extra rear remotes waiting for a use and a big, fuzzy hat
StrangeRanger is offline   Reply With Quote
Old 05-21-2008, 03:06 PM   #27 (permalink)
a better and easier way to mount the screen is with rubber isolators
McMaster-Carr
page1350
that is what i used and comercial makers use them
Old 05-22-2008, 02:42 PM   #28 (permalink)
McMaster-Carr
page1350
Good idea, but how much "give" do they have. Do they allow the screen to shakr rattle and roll?
Also, guys, I need your help. I'm a very literal thinking person (I think inside the box) and I'm having trouble envisioning the shaker part of this thing. Can any of you jump start my imagination please? I'm thinking of using a 3.5hp vertical shaft mower engine for power and a belt to drive something. But I'm just having a total brain fart on what to do. I think what I'm having real trouble with is that I'm thinking of making the screen angle adjustable. Ideas please? Thanks,
**EDIT** Ohh... I just had an idea. I've been making this much harder on myself I think than I needed to! If I have the patience I'll post some drawings
j
__________________
j
Old 05-22-2008, 02:54 PM   #29 (permalink)
Dang, ok, so my idea only helped w/ the angling part of the issue. I still don't really know how to shake the screen. Please, I'd love to hear ya'll's ideas. Thanks,
j
__________________
j
Old 05-22-2008, 03:12 PM   #30 (permalink)
SkunkWerX's Avatar
Some of the commercial units I have seen have coil springs.
I like the idea of an eccentric disc/pulley mounted to the shaker tray.
Or, if not eccentric, weighted so that it creates vibration. The good thing about a weight (Like a bolt and bunch of washers) is that it can be dialed in, by using a smaller bolt, and/or adding or subtracting washers.
Speed can be adjusted via RPM, as well as pulley diameters, but i think you want it running above 1/2 the rated RPMs of the motor, because that is where the power is.
What you need to adjust for is proper harmonics. Each and every thing has a frequency at which it will resonate and feedback causing harmonic vibration.
The trick is to find that spot, where the entire tray assembly is acting like a tuning fork.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
Page generated in 0.18917 seconds with 9 queries
