HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 05-22-2008, 03:37 PM   #31 (permalink)
Default Re: Hey soil screening builders
I made a crank from a 1" cold rolled rod welded to a 3/4" bolt with head cut off offset to one side mounted in 2 1" pillow block bearings
then mounted the pitman arm in the sketch to crank and to bolt welded to angle welded under screen frame
a v belt pully on shaft and engine or motor and your in business
the chain and bungee cord are to stabalize pitman arm
an eye will have to be kept on bungee, you may want to have a spare handy
chickenman is offline   Reply With Quote
Old 05-22-2008, 03:41 PM   #32 (permalink)
AlanB's Avatar
My thought, if I ever get mine together, was car coil springs, free and easy, and using my plate compactor mounted in a frame as the "shaker" Might not work for all, but I already have that peice of equipment and already have to keep that motor running anyway.
AlanB is offline   Reply With Quote
Old 05-22-2008, 03:55 PM   #33 (permalink)
StrangeRanger's Avatar
Send a message via Yahoo to StrangeRanger
Quote:
Aren't car coil springs over kill? I mean, that's gotta be one huge screen fully loaded to make a spring that size move much doesn't it?
After more thinking I think I'm gonna focus on getting the thing working and vibrating and worry about being angle adjustable at a later point in time. Baby steps, KISS method
j
__________________
j
L3400 HST, LA 463 FEL, 6' Woods blade, 65" Woods box blade, 60" Meteor blower, CCM top & side links, 2 extra rear remotes waiting for a use and a big, fuzzy hat
StrangeRanger is offline   Reply With Quote
Old 05-22-2008, 04:21 PM   #34 (permalink)
if it vibrates it dosnt have to be as steep as the waste will work itself to the lower end
Old 05-22-2008, 05:44 PM   #35 (permalink)
SkunkWerX's Avatar
AlanB, you are absolutely on the right track. I would build a "shelf" like a little parking place for the plate compactor, and something to bolt it down.
You'll have a good bit ofthe problem solved, it puts you well ahead of the building curve.
__________________
Kubota BX2350, 60" MMM, FEL w/Grapple, bucket forks, 4' KK Tiller, 5' RGB, 5' Rake, Gauge wheels, 4' Cutter, Quick Hitch, 3Pt. TowBar, 3Pt. 35 Gal. Sprayer.
SkunkWerX is offline   Reply With Quote
Old 05-23-2008, 02:50 PM   #36 (permalink)
Gold Member
Luremaker's Avatar
Quote:
Originally Posted by chickenman
here's my answer to the hydraulicaly operated towed screener
Chickenman, I need you and your screen at my place this weekend. It is finally dry enough to till my garden and I'll have a fresh crop of stones for your screen to pick up!!
__________________
L3130 HST, LA723 Loader, 3pth Snow Blower, 72" Bush Hog, 2 bottom plow, Chain Harrow, Box Blade, Sprayer, Post Driver, Dump Wagon
Luremaker is offline   Reply With Quote
Old 05-23-2008, 03:56 PM   #37 (permalink)
you'll have to get in line behind my stones
i have a half mile track to destone
Old 05-23-2008, 04:12 PM   #38 (permalink)
Do you guys have any idea how much weight it would take spinning around to get it vibrating? I'm trying to do this w/ what I have on hand or can readily obtain. That means going from my mower output shaft w/ probably a 2" pulley to the largest pulley I can get, probably like a 5". I'm thinking of using bolts or bolting weights to the 5" pulley, but have no idea how much weight to start with. Any ideas?
j
__________________
j
Old 05-23-2008, 04:49 PM   #39 (permalink)
my screen takes no weight at all to shake just the crank
its more important how fast than how far
mine has a total travel of under 3/4"
Old 05-23-2008, 05:00 PM   #40 (permalink)
Ok, good to know. Guess I'll just experiment.
j
__________________
j
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
