HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Trackback Thread Tools Search this Thread Display Modes
Old 05-08-2008, 12:42 AM   #1 (permalink)
Iplayfarmer
Iplayfarmer's Avatar
Default Building a Loader for a MF1215
Well, I'm sure some of you saw this one coming. I am too much of a cheapskate to fork out twice what I paid for the tractor to put a loader on it. I've got a big head now from my experience building a hydraulic dump trailer, and now I'm going to build a front end loader for my Massey Ferguson 1215. If all goes well, I'll build a backhoe for it too.
Everyone was so helpful throughout the dump trailer build, and I just had to start this project out by posting here on TBN. I owe MossRoad big for his excellent example of how to post a project. Anyone who hasn't read his backhoe build should dedicate and afternoon to it. It's really pretty good.
I'm just in the planning stage and the accumulating junk stage. I've promised my wife that I will do a few projects around the house before I start work on the loader, but in the mean time I can plan, dream, and keep my eyes out for deals on materials.
There's a tractor and farm machinery wrecking yard about 20 miles away, and the guy that runs the place owes a few favors to a close friend of mine. I took said friend with me on Monday and picked up all the hydraulics that I'd need for both a backhoe and a front end loader.
I got the 5 spool valve and the 3 spool valve in the attached picture plus the 10 rams of various lengths and diameters all for $350. All are guaranteed to work.
I've been using google sketchup to do some initial modeling and figuring. (Thanks hazmat for recommending it to me clear back in September.) The second picture is a shot from sketchup of the loader as it is designed so far. I still plan on considering a load leveling system, and I've got the third spool on the valve to keep my options open for a grapple or something like it.
I'm just introducing the project right now. Be patient with me and I will post back with plenty of pictures, stories, lessons learned, and I'm sure lots of questions.
building-loader-mf1215-hydraulic-stuff.jpg  building-loader-mf1215-loader-plan.jpg
__________________
People get so offended when we treat them like animals. Do you think animals get offended when they're treated like people?
Iplayfarmer is offline   Reply With Quote
Old 05-08-2008, 02:12 PM   #2 (permalink)
blacksmith
blacksmith's Avatar
Default Re: Building a Loader for a MF1215
Nice start. I made one for my MTD 990 tractor. I made my bucket a quick disconnect type. Here is a sketch of the design and the actual brackets made from a cut down angle welded together. The main support tubing was 3.5" Square instead of 4". Here is my 3d drawing of the assembly. The finished loader. If you need any other information let me know. My cylinders are all 2" dia. and 16" stroke.
blacksmith is offline   Reply With Quote
Old 05-08-2008, 10:51 PM   #3 (permalink)
Iplayfarmer
Quote:
Wow! You've got my plans beat by a mile. I love the detail.
What file type are these? I may want to pirate them.
__________________
Old 05-08-2008, 11:39 PM   #4 (permalink)
PAB_OH
Gold Member
Looks like solidworks, AutoCad Inventor, or solidedge (surely not Pro/E??)
Nice models btw. Very nice loader!
__________________
Kioti CK30 HST - KL130 FEL + Toothbar - 84" Rhino LR500 RB - Woods RD6000 - Ford PHD
PAB_OH is offline   Reply With Quote
Old 05-09-2008, 12:53 PM   #5 (permalink)
blacksmith
blacksmith's Avatar
I used AutoCad Inventor Pro. I'm a retired mechanical designer. Now I design things for myself.
Old 05-12-2008, 10:21 AM   #6 (permalink)
Iplayfarmer
Here's my first question to the group regarding this project...
How should I clean out used hydraulic cylinders and valves? I got these used hydraulic parts for dirt cheap, and I want to make sure the cheap dirt doesn't end up in my tractor's hydraulic system.
I have a parts washer with stoddard solvent in it. Is it a good idea to use the stoddard solvent? Should I rig some system to run hydraulic fluid through all of these parts to flush them out before mounting anything to the tractor?
Any and all advice and input is appreciated.
__________________
Old 05-12-2008, 01:47 PM   #7 (permalink)
Renze
Here's how i do it, after cutting and rewelding a hydraulic cylinder to desired length:
I put a bucket half full of diesel, stick the cylinder into it with the oil port submerged, then yank the piston rod in and out untill the diesel starts to foam...
The opening on the top end near the piston rod ?? hmm.... never tried that end. Maybe you have a short piece of hydraulic hose to put into the bucket of diesel, as a suction line.
__________________
Vake bi-j te bange
__________________
1967 Zetor 3011, rebuilt trans, now needs mudguards
1986 Zetor 5245, my old man's tractor, i just own the loader
1996 Volvo 850 TDI
2007 Volvo 440 1.9 TD based dirt buggy, under construction
Renze is offline   Reply With Quote
Old 05-12-2008, 02:01 PM   #8 (permalink)
Kernopelli
I build my loader with the exception of the lift arms. Make sure the cylinder bore is appropriate for your hydraulic flow. It is tempting to put the biggest cylinders you can find on one but especially if you are only using the tractors hydraulics you may not have sufficient flow for bigger cylinders and the slower the loader will function. I love Baums calculators and have found them very useful.
Baum Hydraulics :: Spec Calculator
Tractordata.com lists Your MF 1215 at 4.8 GPM. My Mits is very similar to that and I used 2" lift cylinder (wanted 1 3/4" but couldn't find them for what I wanted to pay) and I certainly wouldn't have wanted to go any larger since its operational speed is just moderate so-to-say. I used 1 1/2" cylinders for the bucket and they work fine and are quite fast but would not have been stout enough as lift cylinders with my configuration.
I never used plans, I just bought the materials and built the sub frame on the tractor. Then uprights, shortened and narrowed the lift arms I had, then did the cylinder placement and control valve bracket and then mocked up a bucket using cardboard and used those pieces as templates for the plate steel I used to make the bucket. I basically just built it piece by piece as I went but it turned out very well over all and was the best thing I ever did. Bought all the metal at the scrap yard, ebay supplied a new CNH joystick control valve and 4 cylinders and Rural King was where I got hydraulic fittings and hoses, pins, bushings and collars. Ended up with about $450-$500 when it was all done.
__________________
Darryl
Mitsubishi MTE2000D MFWD-end loader, 5' box blade, 6' rake, 5' tiller, 72" finish mower, 5' front blade, pond scoop, cultivator.
Kernopelli is offline   Reply With Quote
Old 05-12-2008, 02:27 PM   #9 (permalink)
Iplayfarmer
Funny coincidence... I just found a can of Diesel?/Kerosene? in the corner of the garage this weekend as I was cleaning up. That would be a great use for it.
After the diesel, do I need to get hyd. fluid into in pretty soon, or will the diesel lube and protect enough until I get the whole system put together?
__________________
Old 05-13-2008, 12:11 PM   #10 (permalink)
Grand_Pooba
Member
Grand_Pooba's Avatar
Nice model. I spotted the green/red/blue axis icon in the bottom left corner of your model so I knew it was inventor. I'm a mechanical designer with only 27 years til retirement I design lots of my own stuff...but don't have the time or money build any of it!
Grand_Pooba is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
Page generated in 0.18499 seconds with 11 queries
