#2 (permalink) |
New Member
I wanted a quick attach for a uni-hoe (micro-hoe, bucket curl only) I was building for my small skidkoader (Case 1816). I didn't want to modify the original loader bucket. I found a plan on machine builders network and built it to fit my loader. I bought a service manual for the Case last week and it turns out that Case made a "Tool-Tach" and from the drawings it looks a lot like what I built. It isn't exactly a quick attach, more like a half fast attach, but it should be good enough for use around the house.
![]() ![]() ![]() ![]() ![]() It was hard to keep the holes lined up when welding.
__________________
Daaaad, can you fix this? |
#3 (permalink) |
Check out my design at http://www.tractorbynet.com/forums/b...er-mf1215.html
I built my loader last fall and it has worked out all right so far. |
#5 (permalink) |
New Member
I tacked all four plates (3/8" thick) together, then drilled all holes. I used a vertical bandsaw to cut from the edge of the plates to the hole for the slot. then I ground the tack welds off with a cutoff wheel and dressed the ends with a flap disk on a 4 1/2" angle grinder.
__________________
#7 (permalink) |
New Member
I was checking the fit of the QA yesterday and found a clearance problem. The lower bucket pin hits the bottom corner of the loader arm when dumping. I only moved the bucket forward two inches with the QA so there is only 1 1/8" between the pins (7/8" pins).
![]() ![]() ![]() I may be able to grind the lower corners of the loader arms but I want to study it a little to make sure I don't weaken it.
__________________
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
