HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 06-17-2008, 08:39 PM   #1 (permalink)
Gold Member
Default Core Aerator Parts
So, after breifly shopping for a 60 or 72" Core Aerator for my 3520 I've come to the conclusion that I can easily make a Super HD Version for way less then any I can find locally...
Steel for Frame, Bearings, etc... I can easily source locally, etc... about the only thing I cant find are the "hubs" that I could use with the Core Spoons Agri-Supply carries: AERATOR CORE SPOON 3.5MM - Agri Supply
I couldnt even find the frontier parts breakdown over on JDParts.com
With what Deere & Woods are getting for their units, I think I can put solid gold ballast on my home made unit...
Spudland_Dave is offline   Reply With Quote
Old 06-19-2008, 04:45 AM   #2 (permalink)
Default Re: Core Aerator Parts
I am interested in building some kind of machine to aerate our horse pastures, preferrably up to a foot of depth. (the complete layer of black topsoil)
I voted against the subsoiler with disk openers and rollers behind each leg, because it makes ridges in a pasture like a potato field.
How deep do these core aerators work normally, anywhere close to the 1 foot depth i desire ?
__________________
Vake bi-j te bange
__________________
1967 Zetor 3011, rebuilt trans, now needs mudguards
1986 Zetor 5245, my old man's tractor, i just own the loader
1996 Volvo 850 TDI
2007 Volvo 440 1.9 TD based dirt buggy, under construction
Got tired of WinBlows XP, running Ubuntu Linux from now on !!
Renze is offline   Reply With Quote
Old 06-20-2008, 01:27 PM   #3 (permalink)
New Member
lively1's Avatar
Dave,
I initially looked at going the route of making my own. I even bought most of the metal for the frame, but came to the conclusion it was going to cost more in time and money than buying a new one. I did find a more economical brand than Woods or Landpride. I ended up with a 60" Midwest brand Core aerator. In my opinion it is built as good or better than the Woods and about half the cost. I think I paid around $650 for mine. I have had a few years and large lawns in my area for some extra spending cash... I have about 1,000 lbs of weight on it (used some old railroad track sections) The Midwest brand comes in several colors and the spoons are easy to replace. I bought mine from Little Tractor in Metropolis, IL, but I'm sure you could find a closer dealer for Midwest Equipment (http://www.midwestequipment.net/). Good Luck.
__________________
Lively1
lively1 is offline   Reply With Quote
Old 06-20-2008, 02:32 PM   #4 (permalink)
how deep does your aerator go, with the ballast ?
__________________
Vake bi-j te bange
__________________
1996 Volvo 850 TDI
Old 06-21-2008, 08:55 AM   #5 (permalink)
Gold Member
Quote:
Thanks for the heads up...going into the shopping mode "price blind" I about fell on my rear end when I saw the $2199 sticker price on the Frontier 60" unit on one of the lots...when I saw that I figured I could easily build one cheaper. I was looking at a 72" and according to JD & Woods, they have 96 tines on em, right there is 500.00 worth of tines from A.S. Gonna have to find a Midwest dealer forsure...
Old 06-22-2008, 07:41 AM   #6 (permalink)
My aerator is a little less finished looking but about the same price as Midwest. It came from Sikeston MO. I built a frame and mounted a 50 gal plastic barrel for ballast. I can fill and drain it to match soil conditions. It also makes it easier to handle in the shop with it empty.
Kays Supply is offline   Reply With Quote
Old 07-18-2008, 02:20 PM   #7 (permalink)
New Member
lively1's Avatar
Quote:
I usually get full spoon depth (3-4") depending on the soil conditions. If it is really dry and the soil type is a heavily compacted clay it may only penetrate 2" or so.
__________________
Lively1
Old 07-18-2008, 04:47 PM   #8 (permalink)
Hmm... i'm not sure if i'd find the typical horse hoof compaction in that upper 10 cm... I might have to do some research before deciding if an aerator is the way to go for me...
__________________
Vake bi-j te bange
__________________
1996 Volvo 850 TDI
Old 09-17-2008, 05:19 PM   #9 (permalink)
Don't give up so quick. Do some research and find out who buys or imports the spoons for AgriSupply.
I've found that if you can locate the parts manufacturer, you can often work deals that are MUCH less expensive! Skip the retailer! be persistent and wave cash at them..
IowaAndy
AndyinIowa is offline   Reply With Quote
Old 09-17-2008, 11:23 PM   #10 (permalink)
Gold Member
Luremaker's Avatar
If your are only going to aerate your pasture and you already own a rototiller you may wish to try making some straight blades for it. Straight blades will make thin slices in your soil 4 to 6 inches deep. I wanted to try this last year but ran out of time. I purchased 20 feet of 2-1/2" x 3/8" steel and cut it up to make the blades. I just finished drilling all the holes. All that's left is to sharpen all of the blades and install them on my rototiller. I got the idea from motherearthnews.com My total cost for the steel was less than $25 and I figure it will take less than four hours of my time to complete.
Pasture Renovation
__________________
L3130 HST, LA723 Loader, 3pth Snow Blower, 72" Bush Hog, 2 bottom plow, Chain Harrow, Box Blade, Sprayer, Post Driver, Dump Wagon
Luremaker is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
