HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 05-24-2008, 11:16 AM   #1 (permalink)
New Member
Default water jacket
Has anyone installed a water jacket in a wood stove .any insight or info would be nice with regards to how it works , can it be utilized with a oil hydronic system
crankin76 is offline   Reply With Quote
Old 05-25-2008, 10:24 AM   #2 (permalink)
Default Re: water jacket
Not sure what you mean by a oil hydronic system but i have a thing made up for heating water with a wood stove is portable and hold about 15- 16 gallons.water in this you won't put your hand down in when heated up., is all stainless steel with valve on the side lays about 1/2" above the top of the stove.
fiddler kelly is offline   Reply With Quote
Old 05-25-2008, 02:30 PM   #3 (permalink)
RonMar's Avatar
Quote:
What you are describing sounds like a wood fired boiler. A fire box surrounded by a water jacket. Of course this would work, but in order to keep from boiling the water, you have to move enough water thru the jacket to carry away all the BTU's. If the BTU are leaving in the water, they will of course not be radiated from the stove. This in theory could be more efficient as you are spreading out the BTU over a greater surface area in the hydronic system. Now if you are just looking at better distributing the heat, perhaps a water coil inside the stove that feeds a hydronic system in another room. there are of course hazards and gotta do's to make this work safely.
__________________
Ron
RonMar is offline   Reply With Quote
Old 05-25-2008, 02:40 PM   #4 (permalink)
Willl's Avatar
Quote:
What are you using the hot water for ?
__________________
My PhotoBucket
If you can read this, your 'Ignore List' isn't working.
Willl is offline   Reply With Quote
Old 05-25-2008, 05:56 PM   #5 (permalink)
I use it for washing and doing dishes when i am up to the cabin.
Old 05-25-2008, 06:02 PM   #6 (permalink)
New Member
ive seen what they call a water jacket but it's actualll a flattened out nout coil and you drill an infeed and outlet for the water . it gets heated and sent to your system, mine is a hydronic sytem which is basically water being heated in the boiler passes over to the air handler which is a coil of copper and the air blows by the heated coil and thru the duct work . seems like the stove would do the same task but i guess if a lot of steam was built up an explosion could happen
Old 05-25-2008, 09:15 PM   #7 (permalink)
New Member
We have a wood burning cook stove. It is a Enterprise Monarch. We ordered a water jacket and installed it in the stove. The cold water goes in the bottom and the hot comes out the top and goes to a Forty gallon water heater. We installed a safty valve in the hot pipe just in case the shut off valve got closed. Of course the water heater has a T and T valve also. The water heater is plumbed into our hot water system. We only use the stove in cold weather. It heats all the water the Wife and I need. Just use common sense And it is nice.
__________________
Endowment Life N.R.A. 2810 Mahindra tlb gear
Stihl saws 029, 310
Ram 2500 Turbo Diesel Trailer Tow 2006
20 ft. Hurst Trailer
T.S.C. 3pth splitter
mrpoppy58 is offline   Reply With Quote
Old 05-27-2008, 10:50 PM   #8 (permalink)
Gold Member
RedDirt's Avatar
I've had two cookstoves with connected hot water systems; supplied us with all the hot water needed for seven years living off the grid. Next seven years we ran a "bread-box" solar water heater in the summer and the wood stove water heater in the winter. The principle of operation is thermo-siphon; heat rises.
With a thermo-siphon system the opposite of "heat goes up" is "cool goes down". In use, water is circulated in a "loop" powered by the heat source, in this case the burning wood. As the water in the firebox coil heats it rises and is deposited in the top of a storage tank. Since this is a "closed convection loop" the water in the firebox coil is replaced with the cooler water from the bottom of the tank. As long as the firebox has wood burning this convection cycle continues. The water drawn in may be warm but the firebox is hotter so the cycle continues.
It can take a couple of hours before the tank has heated one cycle. This may be plenty warm enough for dishes and laundry. For bathing you may need a couple of cycles. After several cycles the water can get very hot but it never blew off a conventional temperature/pressure relief valve even though the cooksove sometimes ran 24 hours a day for days (stoked and simmering at night with some semi-green black oak...coals in the morning).
Here are the specifics of building a system:
Both cookstoves had a serpentine series of pipes in the firebox, mounted vertically on the outboard side (away from the "oven side") and ran from the front of the box to the back in length, inlet and outlet outside at the back. The "coil" was 3/4" galvanized pipe (the "coolness" of the water keeps the galvanizing from melting). Both employed threaded "U" bends that used to be common for this purpose allowing about 3/4" -1" between the pipes. The serpentine used three "U"s, four pipes front to back. Cold water enters the pipes the lower pipe and heated water exits the top pipe. This is the extent of the heating side.
The storage system is a 30gal water tank. It is mounted as close to the firebox as possible, usually next to the stove. Two installations had the tank in the kitchen on the oven side of the stove and two installations had tanks in adjacent rooms, once a bedroom and once a bathroom. We always used an uninsulated tank for two reasons. First, by running your hand down the tank you could tell how hot the water was and how much hot water was available. Second, we valued the tank "heat-loss" as an asset, providing a heat sink to release the stored energy into the room during the night.
The tank is plumbed with two inlets and two outlets. Two connect to the firebox loop and the other two connect to the domestic hot and cold water piping.
Plumbing the heat side follows the laws of thermo-siphon. The heat "loop" exits the tank via a side tap about 1/4 from the bottom, connects to the serpentine piping in the firebox, and re-enters the tank in the upper 1/4. Elevate your tank so that the tank outlet to the firebox is level, or a tad lower, than the lower pipe in the firebox. Keep your low tank-firebox- high tank plumbing at least level, or better, running "uphill" from cool tank outlet to hot tank inlet. The thermo-siphon circulation depends on this principle
On the domestic side, cold incoming water is supplied to an inlet in the lower 1/8 - 1/4 of the tank. This can be a side-tank inlet or run down an internal pipe through the tank top like a conventional gas water heater. Heated water for domestic use exits the tank through the top of the tank and connects in conventional manner to your house hot water piping.
I don't know if anyone still makes the "U" bends for the firebox loop. Maybe research boiler or heat exchanger parts. You may need to use a 90 degree street bend and a regular 90 elbow but your spacing won't be as close thus less pipe length for a given vertical firebox height. In a pinch, maybe two black iron or stainless regular 90 degree elbows could be welded. I vaguely recall a friend may have had a copper pipe system and I know copper "U"s are still available. I'd check first on the melting point of silver solder but since the temp relief valve never opened I'd guess a copper/silver solder loop would work as long as the loop was never run dry.
We always used a galvanized storage tank, also made for this use, with the correct inlet/outlet configurations. Perhaps a discarded electric hot water tank could be used if you could find threaded flange fittings to replace the upper/lower electric heating elements. Hydraulic shops have these but they won't be galvanized.
BTW - For those that may have noticed my absence the past few months I got hammered with 50 - 65 hr work weeks on the "other side" of my semi-retirement. I did get the chance to build a root tooth and a trenching "banana" bucket for the BX and a bit of seat time as well as reading some posts from time to time. Hi to all.
Ray
RedDirt is offline   Reply With Quote
Old 05-28-2008, 07:42 AM   #9 (permalink)
New Member
thanx for that info , it will give me something to work on , btw how hot do you think the water reached at its hottest point
Old 05-28-2008, 04:49 PM   #10 (permalink)
Gold Member
RedDirt's Avatar
I don't recall ever making a temperature test but I know that after running several hours you'd have to mix some to plenty cold water to make a shower comfortable. I'd guess the temp, at hottest, would have been around 120 to 130 degrees.
I suspect the temperature could be increased by insulating the storage tank.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
